vdc... turn off completely?
Old Feb 17, 2007 | 12:13 AM
oneformula's Avatar
so, out playing today in the snow... ABS stays with VDC... can you turn it off? also, it seemed to turn back on in very aggressive, out of control maneuvers.... is there a nanny mode? can i turn it off?
Old Feb 17, 2007 | 06:35 AM
John2.5RS's Avatar
Unless there's a fuse for the ABS, it's always on.
Old Feb 20, 2007 | 10:32 PM
Jspeed's Avatar
CV35 6MT
The press release said that VDC is completely turned off by the switch and only comes back on while you're applying the brake.
Old Feb 20, 2007 | 10:43 PM
oneformula's Avatar
hit the brakes and it comes back on? that is pointless... can't be right
Old Feb 20, 2007 | 11:48 PM
KPierson's Avatar
VDC and ABS are two completely different systems. To disable ABS there are a few things you can do, but I wouldn't recomend any of them!
Some people unplug harnesses, some people pull fuses, some people install toggle switches on certain wires.
Old Feb 22, 2007 | 02:04 AM
Jspeed's Avatar
CV35 6MT
Why is that pointless?
Here's the quote...
http://www.edmunds.com/insideline/do...ticleId=110002
"when you turn it off, it's 'off' unless there's oversteer and brake application at the same time."
That means as soon as you finish braking VDC leaves you alone again.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
twentyeggs
Sep 11, 2015 03:58 PM
NJ6MT
Sep 10, 2015 08:40 AM
pasjr1972
Sep 1, 2015 10:17 PM
