any good CAI for the 07 g35 yet?
I doubt there would be much if any gains from an intake. with the dual runners, and the factory "cold air" ducting, you'd be hard pressed to gain anything from and aftermarket unit IMO, other than some noise. I would think that dual short ram intakes would probably cause turbulence at the MAF and cause it to read erratic, and would probably lower the power output. just my 2 cents.
+2. Same goes for the exhaust. 99% of the people who will attempt normally aspirated mods on the '07 will make the car slower. It's pretty much done.
Save your lunch money for boost. The motor is now built to reliably take moderate levels without any internal mods. Combined with the factory LSD, should be a rocket sled.
Originally Posted by terrycs
Hmm ... if I had $$, I might take that challenge. The stock exhaust is 2 into 1 back into 2. Switching to a true dual exhaust should provide some gains for N/A motors and would probably be required for a F/I motor. I wouldn't buy anything unless the manufacturer shows dyno comparisons.
I partially disagree, a certain level of back pressure at different places in the exhaust system will help create/tailor the torque curve - a straight through exhaust is usually not best for N/A engines.
I completely agree about the dyno before purchase of a new exhaust, I think it will be near impossible to gain more then a few HP with an exhaust(or intake for that matter).
I'm sure there are a few ponies to be found with smoother bends and and maybe an X-pipe, but I would think it's pretty well optimized from the factory.
An after market system might bring too much noise, resonance and droning for just a few more HP..
