non-staggered rims/tires
#32
Originally Posted by terrycs
Your are correct, the stock offset for BOTH Journey and Sport is 45mm in front. Only the sport uses 50mm offest in back with the 8.5" rim. Your new wheels should center in the front the same as stock (on the hub) and be 10mm further inboard and 10mm outboard.
You may want to consider adding a spacer in the back to move the wheel/tire closer to the fender and fill out the space giving it a "wider" look.
Should look nice when you lower it too.
I’ve heard people say 35 to 38mm offset on 8.5”er’s is the sweet spot. I think that would stick out too far, but I really don’t know. What is the general consensus a little bit more wheel showing on the outside is a better look?
#33
#34
Originally Posted by fred35
look forward to seeing how these end up looking.
Hope i'm not taking this OT but what's the what's possible as far as width's on the front with 20s?
I think Hikos had 8.5 width on the front of his and railgunner had 8.5s (19s though). Is 8.5 in the front the max as far as the G35s?
#35
#36
Originally Posted by Ghozt
Is there a difference between G35s and non-S for the front wheel setup? I have the base model and I want to get 18" x 8.5 for both front and back, with either 235 or 245 tire. Do you guys see any fitment problem?
The sport is 45mm x 7.5" wide front, rear is 50mm x 8.5" wide.
The main problem is the front. The offset is 50mm on the 8.5 sport wheel, so it might be tucked in too far so you might have to run spacers on the front.
#37
GEE35X,
I am looking at the ADR M-Sprot rim that is 19" x 8.5 with 35mm offset. It shouldn't be a problem with inner clearance, but I am not sure if it will stick out over the fender or not. It sticks out 23mm compare to the stock 17" rim. I probably need to mearsure it. Do you think it will rub if I do a full turn? The back should fit with this rim size, right?
#38
GEE35X,
Why don't you give our site Wheel guru (Chico) a PM. Thats what I would do, he is the most knowledgeable wheel and tire fitment person that I know, and is also willing to help out.
anhhuy88
Archived Sales
07-09-2007 07:40 PM
