Shifting Auto Transmission to DS mode has a lot of features
Old Mar 10, 2007 | 11:49 AM
MY07G35SPN's Avatar
One thing to note on manual mode, the gear numbers are displayed on the LCD screen when you're shifting with the paddle or shifter. The DS and D modes don't. I wish Infiniti enabled gear number display on all modes.
Old Mar 10, 2007 | 12:09 PM
SPEEED's Avatar
Bad Toro
Originally Posted by Garnet Canuck
Daniel, DS mode is "Drive Sport". All you do to engage DS mode is move your shifter to the left, just like MM is on the 1st gen G. DS mode will hold it's RPMs closer to the redline before it shifts and downshifts when de-accelerating. If you don't want to shift manually either with the shifter or paddles, DS mode is a lot of fun.
Thanks for the explanation Shane. Onto the next question then:
Is there a difference between moving the shifter to the left as oppose to simply being in Drive and then engaging DS by using the paddles? (as oppose to moving the shifter to the left first).
Old Mar 10, 2007 | 12:47 PM
detracti's Avatar
Especially in DS mode. When I try to "left-paddle" from DS mode, it downshifts, which makes me cringe when I'm going too fast for the next gear down. So, instead, to get to manumatic mode I do a rapid "right-paddle..left-paddle".
If the gear number were displayed, neither would be necessary.
Old Mar 10, 2007 | 01:26 PM
kring's Avatar
I mentioned a while back that was onel of my minor issues, I really wish there was a gear indicator while in D or DS. but so far I've found that when ever you put the car into DS it drops you 1 gear. so if your in drive and in 5th gear and want to get to 3rd, put the car in DS and downshift only once.
I know you really don't know for sure what gear D has you in, but as a general guide, D seems to put you in 5th gear any time your doing more then 40 mph, 20-40 mph is 4th gear.
Old Mar 10, 2007 | 11:02 PM
chuckg35's Avatar
shift down or up in D and the gear will be shown, just as it is in DS mode
Old Mar 10, 2007 | 11:59 PM
Garnet Canuck's Avatar
Traveling Administrator
If I am understanding your question correctly Daniel, yes there is a difference. If you engage DS mode by moving your shifter to the left, everything is done for you whether it being upshifting or downshifting. If you engage your paddles, you are in full manual mode meaning that it will hold whatever gear you are in until you shift again. (but it in MM it will downshift for you if you don't manually downshift yourself) Make sense?
Old Mar 11, 2007 | 03:12 AM
MY07G35SPN's Avatar
Gear will be shown but only for a few seconds and then it displays D again.
Old Mar 11, 2007 | 01:59 PM
SPEEED's Avatar
Bad Toro
Yes it does!
Thanks Shane.
mjfenix
Aug 17, 2017 05:49 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
derres
Aug 28, 2015 03:27 PM
nervseele
Jul 17, 2015 11:21 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
