Car is in the shop getting H&Rs NOW...
Old Mar 13, 2007 | 02:31 PM
hokiesean24's Avatar
The Eibach drop is less than the H&R? I thought the Eibachs were supposed to be lower than the H&R?
At any rate, I like the front a lot.... its just the rear. Maybe I should get a set of 350Z springs, swap the rears and decide what I like?!?!
The alignment issues arent bad enough to hurt it too bad as it is?!?!
Old Mar 13, 2007 | 02:45 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Guys... if you want to bring the rear up a tad, you can install these spring pads.
From here: LINKY part # for the spacer #9.6101
Old Mar 13, 2007 | 02:49 PM
Interesting... anyone have any experience with these??
Old Mar 13, 2007 | 02:50 PM
InTgr8r's Avatar
Just us OF old timers
... actually I just did the same thing in my Z4M.
Installed H&Rs & added a thicker perch pad to even the drop.... worked great!
Old Mar 13, 2007 | 03:06 PM
Cyanide Ride's Avatar
Originally Posted by Hikos_G
OEM coupe/Z springs for an even milder all around drop.
From what I've seen so far, the order of mild to extreme drops so far is ~
1) OEM Coupe/Z springs
Wha? wha? wha? wa, wah, wuuuutt?!
Hold on there gentlemen, you're telling me that the stock springs on the coupe/Z will fit on the '07 G and offer a slight drop but not as low as Eibach or H&R?!?!?
Whoa.
My next question would be, do the part numbers line up with the AWD versions of the G?...
Old Mar 13, 2007 | 03:20 PM
terrycs's Avatar
2) Eibach
3) H&R's
4) Airbags
I think historically:
2) Tein H-Tech
3) Eibach Pro-Kit
4) H&R's
5) Eibach Sportline or Tein S-Tech
6) Airbags
Old Mar 13, 2007 | 03:21 PM
terrycs's Avatar
Whoa.
There is one lowered G35x in the forums already.
Old Mar 13, 2007 | 03:24 PM
acidrane's Avatar
i was actually thinking about this. i didnt know they had an actual part for it!
Old Mar 13, 2007 | 03:31 PM
So, noone thinks the 'spring pads' idea would do anything detrimental? It wouldnt mess anything up or hurt the performance (as much as mixing springs)? I mean, hell, I could order a few sets of them and experiment, they are cheap enough...
I will post some pics this evening!
Old Mar 13, 2007 | 03:32 PM
Here is my Alignment Spec Sheet...
Old Mar 13, 2007 | 03:33 PM
Hikos_G's Avatar
Whoa.
Take a look at the older G sedan threads. There are tons of people who've done it to get just the right amount of conservative drop. Not too sure about the exact details about which works best, G-coupe or Z springs, and why but there are countless threads about it.
Old Mar 13, 2007 | 03:47 PM
Serves me right for being eliteist and only hanging out in here...
I'll start searching right away thanks guys!
Old Mar 13, 2007 | 03:51 PM
WTH...
I think they used '06 AWD Alignment Specs!!! Frickin Idiots!
Anyone have ANY idea if my car is ALL out of whack or not?!?!
Old Mar 13, 2007 | 03:54 PM
terrycs's Avatar
The front camber is comparable to what railgunner had for his H&R springs.
Your rear camber is farther out than railgunners.
I'd recommend an alignment kit unless you can afford premature tire wear.
Old Mar 13, 2007 | 03:56 PM
  #30
terrycs's Avatar
WTH...
I'll PM you the specs.
