Bluetooth detection issues
Old Mar 26, 2007 | 08:08 AM
SPEEED's Avatar
Bad Toro
Does anyone else have issues with his/her phone getting detected?
Sometimes the phone is automatically detected as soon as I get in the car. At other times, it doesn't. As a matter of fact, if I then go to the Bluetooth menu on my phone (Verizon LG VX8100), It has a message on the screen (phone screen) about the phone being disconnected (bluetooth wise). If I try to force it to connect, it takes a few trials. The first and second, and usually third attempt - all fail. Then on the 4th or 5th attempt it connects...
Can someone shed some light on this?
Old Mar 26, 2007 | 11:21 AM
mhleung's Avatar
Some phones are just meant to NOT work with the G.
My "newer" phone, Samsung D600, has all the bells and whistles, including bluetooth. Imagine my horror on the day I picked up my new G...I spent an hour at the dealer, trying to pair up the phone with the car. No luck.
I have just switched back to my MUCH OLDER Sony Ericsson T610. Bingo! Worked first time, and I can even send contacts.
Perhaps our problems are how bluetooth was implemented on Samsung and LG phones. SE phones are much more stable when it comes to BT.
Good luck to you.
Old Mar 26, 2007 | 11:27 AM
SPEEED's Avatar
Bad Toro
My phone (when connected) seems to work flawlessly. I didn't have any problems pairing it when I picked up the car. Even the signal strength and battery meter seem to work correctly. But from whatever reason, sometimes when I enter the car, the phone is not detected automatically - I need to do it manually by forcing it to connect...
Old Mar 26, 2007 | 11:33 AM
CalsonicVQ's Avatar
Don't give up! My Samsung T809 was doing the exact same thing. Then one day I changed some of the settings under "bluetooth" in the phone, and it's worked fine ever since. Sorry, I don't remember which setting(s) I changed. Good luck!
Old Mar 26, 2007 | 11:57 AM
Blaxima's Avatar
I have the same phone and the same sporatic issue as you. I found that if I turn the phone off and then back on it reconnects fine. I'm not sure what the problem is, and I haven't been able to see a pattern.
Old Mar 26, 2007 | 12:11 PM
G-Whizzer's Avatar
(4) Motorola SmartPhones between my wife and I - all hook up without error...
The 2 most recent do sound better (less echo) -
Old Mar 26, 2007 | 01:12 PM
SPEEED's Avatar
Bad Toro
This is definitely weird, but the more I think of it the more I lean towards blaming the phone....
Old Mar 26, 2007 | 01:36 PM
SPEEED's Avatar
Bad Toro
Originally Posted by treacherous
My wife is on her second 8100. First one had Bluetooth fail on it. Maybe it's a common failure in that model.
Hmmm... Time to go see the local VZ rep.... New phone time?
Old Mar 26, 2007 | 01:55 PM
UltimateGee27's Avatar
Yea maybe its that model phone you have? I own a Cingular 8125 and i must say the blue tooth works like a charm. Much better than the Lexus, and way better than my Finace's TL.
If you dont mind having a touchscreen phone id suggest this phone its not to bad.
Old Apr 6, 2007 | 03:16 AM
SuperCharged's Avatar
The only T809 + G35 bluetooth success story?
Just wondering if you ever had any audio trouble with your T809, or just pairing problems. It seems all other posts regarding T809's bluetooth connectivity make it all but useless in the G, same with my T809.
Old Apr 6, 2007 | 07:30 AM
dcmidnight's Avatar
Same problem here with my Treo 700WX. Paired just fine from Day 1 and ran great for a few months. Lately its been having connection issues. Going to try to re-pair the phone and see if that helps any but I blame the phone and not the car.
Old Apr 6, 2007 | 07:39 AM
SPEEED's Avatar
Bad Toro
I think I've figured the problem. I had another device (my home PC) saved on my phone under "Paired devices". I removed the PC and I haven't had the problem since - that was two weeks ago.
Old Nov 5, 2007 | 10:22 PM
mhleung's Avatar
An update after 7 months...I got a new phone last Wednesday...the new Nokia N95 8GB. Bluetooth works flawlessly, I am happy to report!
Old Nov 6, 2007 | 09:17 AM
Lunchman's Avatar
My current phone, the Samsung Sync works great. It is automatically detected when I start the car, and makes and receives call through bluettoh in the vehicle like a champ. I do want to move onto the iPhone, but am concerned if I will get as good service as I do with this phone + car currently.
Lunchman
Old Nov 6, 2007 | 11:24 AM
westsideg35's Avatar
My Verizon LG VX8600 will not connect sometimes. I just turn it off and turn it back on. That works most of the time.
