Nitrofill
Old Mar 29, 2007 | 01:21 PM
SPEEED's Avatar
Bad Toro
Nitrofill
Anyone else picked up his/her 2007 sedan with nitrogen in the tires? I was given a registration card with a member number to register online at www.whynitrofill.com, which would entitle me for various road side assistance overages and free nitrogen refills….
Anyone?
Old Mar 29, 2007 | 07:25 PM
kring's Avatar
Anyone?
Yes I filled out the registration and I'm all set.
Old Mar 29, 2007 | 07:44 PM
G-Whizzer's Avatar
Geesh. I didn't get that....
I better find out why. Maybe it's not permitted in California - along with almost anything else worth having or doing.
Old Mar 29, 2007 | 08:04 PM
sjharris's Avatar
I didn't get it either. And I got my car at the same deaeler as SPEEED.
Old Mar 29, 2007 | 09:29 PM
SPEEED's Avatar
Bad Toro
Call Manny and have him check on that for you. If I had to guess it probably has something to do with the different tires we have (X vs. Sport).
Old Mar 29, 2007 | 09:30 PM
SPEEED's Avatar
Bad Toro
So what do I do now? Especially when I need to refill my tires....
Where do I go?
Old Mar 29, 2007 | 10:06 PM
kring's Avatar
Where do I go?
well you shouldn't need to refill your tires, that's the cool part about nitrogen! it doesn't seep like regular air or get effected by temperature changes as much. The dealer will check and add nitrogen as needed during your regular maintenance.
Should you find the pressure too low, or you get a flat and need to add air, just use generic air, but make sure when you go in for your next oil change tell them which tire you added air to and they will purge and refill the tire with nitrogen.
BTW, Manny was my salesman as well, looks like 3 of us went to Devan.
Old Mar 29, 2007 | 10:10 PM
izmir41500's Avatar
G35driver Addict
air is 80% nitrogen. doesn't really matter as long as you get it for free at the dealer.
Old Mar 29, 2007 | 11:06 PM
daluder's Avatar
Ok if air is 80% nitrogen and normal air leaks out of tires then after topping off the tires a couple of times wouldn't most of it be nitrogen? is the dealer giving this stuff out then you have to pay for it down the road.
Old Mar 30, 2007 | 07:06 AM
kring's Avatar
Actually quite the opposite happens, it won't become pure nitrogen because of other molecules found in common air, such as oxygen which has corrosive properties, and most importantly, water which can turn to gas and back to liquid while driving, causing increased pressure exactly when you don't want it which is under performance when tires heat up. when you top off, you are adding more moisture to the tires, the tiniest bit of moisture far outweighs the small % of other gases that do seep through the tire over time.
no it's free for life as long as you registered.
I recommend hitting the site for information.
The airline industry is required to use nitrogen filled tires, all racing vehicles use nitrogen and so do many industrial vehicles. While the benefits are not blaring, they are subtle and do exists... and when it's free! who could possible complain!
Old Mar 30, 2007 | 07:10 AM
95se's Avatar
Anyone get this on an X? I've got an X and there was no nitrogen talk.
Old Mar 30, 2007 | 07:20 AM
SPEEED's Avatar
Bad Toro
Cool
Looks like I did a good move with this dealer a second time
Old Mar 30, 2007 | 06:26 PM
sjharris's Avatar
I asked my service advisor about it about a month ago. According to him Devan started to use it in late December in all the New Gs. He said if I wanted it, I would have to pay for it. They quoted me 69 bucks as i posted here
https://g35driver.com/forums/showthr...ighlight=nitro
They also said I would have to pay that every year.
Also, I think Devan is the only place to get it filled around here.
Old Mar 30, 2007 | 09:00 PM
SPEEED's Avatar
Bad Toro
That sucks bro
I hope they don't charge me come next year...
Old Apr 4, 2007 | 04:23 PM
sjharris's Avatar
i just got the car back again and the darn TPMS light won't go off. I am getting a little sick of going back to the dealer.
