Antenna Adapter
Old May 2, 2007 | 02:05 PM
bfspider's Avatar
Antenna Adapter
Does anyone know the correct antenna adapter to use so the standard antenna plugs can fit? I was able to get to the back of the AV unit while installing my HD Radio adapter and noticed that the plug is quite small for the antenna.
Did some searching around, and the closest thing I could find was a 40-NI11 from Metra.
Any ideas?
Thanks.
Old May 2, 2007 | 03:21 PM
hokiesean24's Avatar
I do not know the answer to your question, but I would be interested in a DIY outlining the procedure and products you used. I am interested in adding an HD tuner to my stock setup as well.
Old May 2, 2007 | 09:13 PM
bfspider's Avatar
http://www.bestbuy.com/site/olspage....=1173577734672
I picked up the Zoom HD radio adapter from best buy (link above) after selling my old HD deck from my previous car.
I followed the 07 G35 Service manual on how to get behind the Auido/Video controller.
Off the top of my head, after you pop up the boot frame where the shifting handle is and using channel locks to remove the shift ****, you can pretty much pull off the few things you need to get behind the radio. After figuring out that I needed an adapter - I had to put things back together. Next time when I take it apart, i'll have my digi cam with me and take some pictures along the way.
If anyone has any ideas on what adapter to use, lemmie know~
Old May 2, 2007 | 10:09 PM
Thanks, take a look for an input to the hard drive as well!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
Danielek
Sep 10, 2015 06:18 PM
