Clear coat on stock grill
Old May 8, 2007 | 09:16 PM
joeldoss's Avatar
My dealer has agreed to replace the grill on my new 07 sedan due to several rock chips.
Would it make sense to spray several coats of clear finish on the new grill before installing it? Wondered if that might help protect it. Certainly cheaper than clear bra on the grill.
Old May 8, 2007 | 09:18 PM
link's Avatar
a few strips of clearbra are only a few bucks and a little elbow grease.
you can buy 2" strips at stickercity.com
Old May 8, 2007 | 10:48 PM
terrycs's Avatar
Interesting idea with the film.
But I have to wonder if the film itself will pull of the plating if you ever decide to remove it.
Old May 9, 2007 | 08:07 AM
hokiesean24's Avatar
Probably! I am convinced it would chip if you gave it a mean look...
Old May 9, 2007 | 09:41 AM
kring's Avatar
Confirmed... When I saw all the chips with only 4K miles while I was waxing it over the weekend I growled at it and 3 more chips appeared.
Old May 9, 2007 | 01:03 PM
figured as much... P.O.S.
Old May 9, 2007 | 04:19 PM
Altersys's Avatar
i have no idea how well the clearcoat will adhere to the surface... it's not primer.
Old May 9, 2007 | 04:40 PM
ttrank's Avatar
Grocery getter
I doubt it. I took the clear bra off my hood and didn't have any problems. Might try a few coats of wax on it before you install the clear bra. Just make sure and let it cure for 24hours before you put the bra on.
Old May 10, 2007 | 09:02 PM
iandi's Avatar
Which clear bra did you get? Did you install it yourself? Why did you remove it?
Old May 10, 2007 | 10:06 PM
link's Avatar
you're not supposed to put wax underneath the bra film.
you can put wax over it though
skippyG
Jan 25, 2016 01:18 PM
rsingerG35
Aug 18, 2015 10:16 AM
linedr89
Aug 17, 2015 05:11 PM
nervseele
Texas
Jul 29, 2015 08:49 PM
