I wish I could see eibach & H&R together so......
May 28, 2007 | 11:43 PM
makes sense.
Reply 0
May 29, 2007 | 12:15 AM
Quote: Here is mine after install, BUT before camber kit. My right rear was 1/2" lower in the factory state. I took to Infiniti and they said they'd put a new spring on it but nothing was wrong with it. I used Dial Calipers to measure before and after. The rear dropped .12" more than it was supposed to 1.42". The front dropped 1.27", .13 less than it was supposed to. They said give it a couple of weeks and the front should settle more than the back. ?? For some reason the RR corner is 1/2" lower before and after Eibach install.
Looks good to me! Kinda hard to tell where the OD of the tire is in the photos though.
By the numbers though, 0.12 / 0.13 is about 1/8". I think that amount is hardly noticeable. I bet you can raise the back more than that by stopping hard, setting that parking brakes, then taking your measurements! Interesting about the 1/2" RR though. I guess you never noticed it until you put calipers on it.
Springs don't settle. It's usually the rubber isolators that take a compression set. The front ones are thicker than the rear ones, so your installer is probably right.
Reply 0
May 29, 2007 | 01:04 AM
Here are a few more: I did a quick wash to insure my lawn got some rain. The right rear is not a huge noticeable difference, but I can see it from behind.
Reply 0
