2nd Service: Oil Change or Full Schedule 1?
Old May 30, 2007 | 05:26 PM
Christian's Avatar
It's time that I need to book my second service for the G, am I ok with simply getting the oil changed or do I need to have a full check up done?
The tires don't need rotating and I really doubt there has been significant wear on the brakes or other systems at this point.
Will there be any impact on my warranty if I go with the schedule 2 service that is just an oil change and leave the check up for the 24k service?
Old May 30, 2007 | 05:40 PM
CalsonicVQ's Avatar
Of course you go with just the oil change unless you have tons money to burn. But if that were the case, you probably wouldn't have bought a lowly Infiniti. =)
And no, there can be no possible impact on the warranty since you are following a recommended maintenance schedule. Also, all maintenance should be documented.
Th611
Oct 27, 2015 03:48 PM
Ednica87
Sep 5, 2015 02:59 AM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
ClwMike
Jul 23, 2015 12:55 PM
