Where is the automatic transmission dipstick?
Old Jun 2, 2007 | 11:52 AM
treacherous's Avatar
20 Year Member
G35x
Where is the automatic transmission dipstick? Or is there another method for checking level, color and smell of automatic fluid? I had not thought about it until I did an oil change this morning. I looked around engine bay and didn't see anything. I didn't find anything in service manual as well.
Thanks!
Old Jun 2, 2007 | 02:50 PM
terrycs's Avatar
Thanks!
Interesting ... pg 8-12 of ops manual says let dealer chack ATF level. I guess they must have buried it in there somewhere.
Old Jun 2, 2007 | 04:02 PM
Triton3.5's Avatar
Its in the back,,,, 10 mm bolt to undo it... its slightly easier when you take of cosmetic, engine cover... slightly on pass. side...
Old Jun 2, 2007 | 05:38 PM
Msedanman's Avatar
O.F. Administrator
Interestingly, Canadian G's (and M's) come with a proper handled dipstick complete with the 10mm hold down bolt, which can be purchased to replace the US version that has no handle and is not meant to be checked by the owner.....
Not sure why they do that but they do.
Colin.
Old Jun 2, 2007 | 06:03 PM
Msedanman's Avatar
O.F. Administrator
Is the fill tube more readily accesible than the American version? It's not a big deal to remove engine cover but I was actually surpised how relatively hidden this service item was. Of course... the hold down bolt was also intriguing to me as well.
The fill tube is in the same place, but with the handle on the dipstick, it makes its removal very easy...
Colin.
Old Jun 13, 2007 | 09:01 PM
G35inSD's Avatar
Anyone know how to properly read the dipstick level? Should it be within the area labeled "HOT" or should it be in the crosshatched section? My fluid was way above the crosshatched section all the way up to were the dipstick starts the S shaped bend.
I am checking it after having driven at least 10 minutes. I pull onto a flat surface and shift through P,N,D,R... then leave the car idling and check it. Is this correct????????????
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Chauzilla
Sep 27, 2015 04:34 PM
blnewt
Sep 25, 2015 01:48 PM
