oil change: 3000 or 3 months
Originally Posted by G35_TX
Well its because Mobil 1 is no longer a full real synthetic. They changed their formula recently.
Amsoil, Redline, RP are full PAO Synthetics. A cheaper shelf bought synthetic that has been showing better results than M1 lately is Penzoil Platnum.
I should just consider buying Amsoil by the case; Vans locally wants like $10 a qt.
Originally Posted by BrianV
What about Castrol European Formula? Isn't that a full synthetic? I planned on trying that. Although I've used Amsoil A LOT in the past, and think it's phenomenal oil, I'm not one to order ahead, etc. I change oil more on convenience of schedule so I prefer just walking into a local shop and buying my parts. I can get the Castrol Euro Formula at Autozone.
Originally Posted by Jeff92se
On what technical basis are you basing your 3k change on?
I think the oil changing is as personal as the lease vs. buy debate. Personally, on my Maxima I do it myself 5k with Castrol 5W30, and an OEM filter. I feel that's more than adequate.
I'd follow the G35 owner's manual, but somehow I doubt it says 3k. If it did, it'd imply its motor somehow needs quite frequent oil changes.
Yes the European Formula is a full PAO synthetic. I forgot about that. I just order the Amsoil directly for like $5 something a quart when I get a case.
Originally Posted by John105
Uncle Jiffy (Lube) says so!
And to think the brochures raved about microfinishing since 1994!
Is that the regular price or are you using some dealer account?
I am a dealer for myself and a few friends really. But the dealer or just becoming a member with Amsoil so you can order directly the cost is the same.
Talkinghorse + maxima.org = profit
So becoming a "member" is different than just buying from their online store?
Ed may actually get the product cheaper. An example is my experience with Shaklee. You can sign up to be a member and get the product at member cost, but if you sell a certain amount you can get the products at just slightly lower than member cost. On top of that you get commission based upon volume of selling. Ed's seems like a pretty stand up guy and has always provided me great customer service. I hope my little bit of purchases helps him out. Generally for most it's not a very lucrative business, but I imagine it could be some good change if he does well.
