Check this out...3.9 gears for 6mts
Old Jul 23, 2007 | 04:52 PM
rlwjr1's Avatar
I'm not disputing the merits of higher or lower gears. I am just making fun of those that are so concerned with their top end. If you have spent any time on a major freeway in a major city you will know what I mean.
DOMO <<<< Doin' the can't get over 35mph dance, on yo' face....
Old Jul 23, 2007 | 05:11 PM
redlude97's Avatar
Originally Posted by g35_6gear
A taller gear will not be decrease to speed..it will do the opposite. Why do you think the salt flat racers use a lower # (taller) gear for higher top speed. They get more tire revolution for a given rpm with a taller gear and more top speed. This is why they need a push start because the gears are so tall.
You are right, I always get taller and shorter gears mixed up, since it goes against the increased"numbering". I meant a higher numerical final gear ratio ie 3.5->3.3
Old Jul 23, 2007 | 05:19 PM
g35_6gear's Avatar
Lsst time I checked nobody was attempting a land speed record just attempting to have a technical discussion.
Old Jul 23, 2007 | 06:26 PM
rlwjr1's Avatar
Sorry, just trying to have some fun. Just for giggles go try this... http://www.csgnetwork.com/speedcalc.html
One thing that needs to be taken into account is the engine. Yes a F.I. motor has the power to pull a high gear such as a 3.23. A basic N/A motor may actually go faster with a lower gear because it would allow the motor to pull higher in the RPM range in O.D.
As the above web site shows, yes a 3.55 rear gear and O.D. , I figured 0.68:1 6th gear, will do a theoretical 212 MPH. We all know aerodynamics and power will not allow that on a factory car.
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
2_Liter_Turbo
Jan 19, 2018 01:48 AM
Th611
Oct 27, 2015 03:48 PM
rpm&my_G35
Canada
Sep 18, 2015 08:08 PM
Frostbite91
Aug 20, 2015 07:20 PM
