In-Dash Component Video: What Devices Work?
Old Jul 30, 2007 | 10:51 AM
G35 S's Avatar
I think I have seen a thread that had the solution to make it work while the car was in motion but no one dared to do it. You had to take apart the entire center console or something like that.
Old Jul 30, 2007 | 12:42 PM
Christian's Avatar
Originally Posted by whtbst
japhule: I just tried going to Display in my Settings and there is no option to switch to TV. Dangit. Also, I don't have an iPod, I have an iPhone...maybe it doesn't have a video out?
G35Five_O: I'm using the Apple iPod brand AV cable, red/white/yellow to 3.5mm jack.
I've never owned an apple computer, so I can only speak from experience with my windows notebook but I press Fn F7 to switch between my main screen and the TV out/vga out. I needed to enable the TV out in my display properties first. I did a quick google image search for the powerbook keyboard and it looks like it may be the same.
If this is the same layout as your powerbook it may be worth a try.
Old Jul 30, 2007 | 01:17 PM
whtbst's Avatar
G35_S: Yeah, you're right...but I am definitely not going to try it! Plus, I don't think watching DVD's while driving is the safest move anyway...hahaha.
ChristianN: Thanks for the search, this is exactly what my PowerBook keyboard looks like, and I think you might be right re: hitting F7...looks like that double/overlapping screen icon means you can toggle back and forth from different display sources.
Old Jul 30, 2007 | 01:18 PM
Christian's Avatar
Just to clarify I think you probably need to press fn+F7
Old Jul 30, 2007 | 01:23 PM
whtbst's Avatar
Nope, simply hitting F7 by itself seems to work. Thanks again.
Old Jul 30, 2007 | 01:25 PM
Christian's Avatar
Awesome! Now that you're not struggling with that anymore maybe you can explain to my why you want to look at a 7" screen instead of the 15" right in front of you.
*I thought I should ask my stupid question after posting a possible solution
Old Jul 30, 2007 | 01:51 PM
whtbst's Avatar
hahaha, because i wanted to see if the in-dash video actually worked or not! and i also wanted to see how good the screen quality was. but good question!
Old Jul 31, 2007 | 09:40 AM
turboale's Avatar
One big motha...
It sounded like one guy was having trouble getting his to work at all...
Make sure the parking brake is set, otherwise you will need a "special" switch. But we are not allowed to talk about that here publicly. If you have any questions I have added the magic switch to my car and it works flawlessly. As for using your mac, what os are you running? If your running OSX all it takes it to plug in the rca-out dongle and click the monitor icon in the top right corner and click "Detect Displays". Once it turns on the video out it will change resolution and that same menu will give you the option of having two separate screens or two of the same (mirrored). If you don't have a monitor icon at the top right of your screen you have to turn it on in the "displays" portion of the System Preferences under "Show Displays in Menu Bar". Its a good thing to keep up there, especially on laptops. Let me know if you have any other questions!
WillisFL
Dec 29, 2016 08:56 AM
justgotg35
Jul 19, 2015 12:33 PM
beevanhuynh
Jul 14, 2015 09:06 AM
