Bulletin Posted: ITB 7028 "Cruise Control Surges When Going Downhill"
Old Aug 12, 2007 | 05:02 PM
treacherous's Avatar
20 Year Member
G35x
Maybe someone can post full bulletin. This is from Tech Info site.
ITB0702
IF YOU CONFIRM: When in Cruise Control mode, customers may report experiencing a mild speed fluctuation when the vehicle is traveling downhill. ACTIONS: Confirm this bulletin applies: Check and compare your Current ECM Part Number to Table A on page 6. If that part number does not match one in Table A, this bulletin does not apply. Go back to ASIST for further diagnostic and repair information. If applicable, reprogram the ECM. NOTE: This vehicle’s ECM is reprogrammed using CONSULT-III (C-III).Instructions on how to use C-III to perform reprogramming are contained in the attached Service Procedure. See this bulletin for further details.
EDIT: I've had this happen to me so this is one I plan to have addressed.
Old Aug 12, 2007 | 08:26 PM
Garnet Canuck's Avatar
Traveling Administrator
Good find man! My G does this so this will definitely be a TSB that I get done. Btw, I've posted it in the FAQ thread.
Old Aug 12, 2007 | 09:21 PM
Christian's Avatar
I have ICC so this doesn't apply to my car. Those of you who don't want to bother with signing up at infinitihelp.com, you can download from my server here:
http://www.infiniti-x.com/ITB07-028 ...se Control.pdf
Old Aug 12, 2007 | 09:36 PM
bkrider's Avatar
Thanks for letting us know about this. My G35S 6MT surges like crazy going downhill, sometimes it almost feels like someone tapped the brakes. I will definitely mention it when I bring it in in Sept for service.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
markbilo
Sep 30, 2015 01:33 AM
