Does your speed sensitive audio work?
Old Aug 20, 2007 | 06:06 PM
Als35's Avatar
I can't seem to tell the difference on the speed sensitive audio. I've tried different settings but the sound level doesn't sound like it's adjusting with the speed of the car.
Old Aug 20, 2007 | 06:09 PM
IsaG35's Avatar
I know mine does when I have it on the highest sensitivity but whats funny is the faster I drive the better it sounds (the music gets louder) so when I slow down it gets pretty quiet..
It seems like it the sound goes lower than I originally set it at when I stop at a light..
Old Aug 20, 2007 | 06:19 PM
TheIvoryG's Avatar
I don't notice mine until I stop somewhat suddently at a light in a quiet area...then I can hear it get lower all of a sudden likes its catching up. I guess that's what I want though...I don't want to feel like I have to increase my volume while driving on the freeway, and I don't feel like I have to.
Old Aug 20, 2007 | 08:34 PM
surfwb86's Avatar
mine works. I haven't messed with the settings but it's pretty noticeable in my opinion.
Old Aug 20, 2007 | 08:56 PM
G-Whizzer's Avatar
You MUST have the radio on for this feature to work!!
LOL.
Old Aug 20, 2007 | 09:33 PM
SVLRx's Avatar
mine works, most cars i've driven are all about the same as sensitivity goes..
Old Aug 20, 2007 | 10:35 PM
ugaexploder's Avatar
i noticed it only gets loud once i put it in drive, i must not have it on...personally i don't think i want it on
Old Aug 20, 2007 | 10:56 PM
BlackGSedaN1027's Avatar
I notice it louder @ about 55-60mph
Old Aug 20, 2007 | 11:59 PM
ON_6MT's Avatar
mine doesnt - wire is cut
Old Aug 21, 2007 | 12:15 AM
Jim123's Avatar
I have mine on a setting of 4 and it's pretty noticeable.
To the OP: Nice Z06 in your avatar.
Old Aug 21, 2007 | 08:25 AM
SPEEED's Avatar
Bad Toro
Actually that's the whole point of the system - you shouldn't notice any difference in sound. If you're actually saying that the road noise is overpowering the audio at higher speeds, then yes, check the settings and if nothing works take it to the dealer. Otherwise, if all you're saying is that you don't notice a difference in audio level when accelerating, yet the sound level is still at proper volume - that means the system works.
The best test is to hop on the highway and just gun the car. The instant jump in speed and RPM should create an instant bump in volume (rather than the gradual increase), which you should definitely be able to hear.
Good luck.
Old Aug 21, 2007 | 08:36 AM
thedriver's Avatar
Yep, like Speeed said, it's meant to go unnoticed. I had the same feature in my last Focus (wierd eh?) and it was very noticeable which means it wasn't quite as smooth of a system. I have it on the highest setting in the G and don't really notice it that much which is perfect.
Old Aug 21, 2007 | 12:28 PM
Als35's Avatar
I guess I'll have to take it in to the dealer for a fix. I'm having to increase the volume manually at higher speed. Volume should increase noticeably at setting 5, correct?
Old Aug 21, 2007 | 12:47 PM
st1sj's Avatar
i turned mine off, b/c i dont like the auto adjustment.
Old Aug 21, 2007 | 04:34 PM
Jim123's Avatar
I have mine set at 4. If I listen for it I can sense it getting louder as the car gains speed.... especially quick acceleration to 50+ mph.
Mry
Mar 3, 2023 01:03 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cacoepy
Aug 3, 2015 01:09 PM
Frostbite91
Aug 2, 2015 04:59 PM
