Bulletin Posted ITB07030 - 06-07 G35; Shudder at 40 MPH
Old Aug 28, 2007 | 09:01 PM
treacherous's Avatar
20 Year Member
G35x
https://www.nissan-techinfo.com/infi...RefNo=ITB07030
IF YOU CONFIRM The vehicle has a shudder when the transmission is at operating temperature and the torque converter is: Engaging lock-up in 5th gear (light acceleration at 40 mph) and/or releasing the lock-up in 5th gear (coasting at about 40 mph). ACTION Replace the transmission valve body (control valve assembly). See this bulletin for further detail.
Old Nov 11, 2007 | 11:09 PM
Allenzi35's Avatar
This is for the 06 sedan only.
Old Nov 12, 2007 | 01:30 PM
silverG2007's Avatar
I tried to use this for my 07 sedan, I was shut down.
On the plus side, the Cruise control ECU reflash fixed my 40mph shudder. I was surprised I had the same exact symptoms as this bulletin and a tune fixed it.
Old Nov 13, 2007 | 02:17 PM
It must change the tq converter lock up parameters because mine definitely changed. Before (part of the problem) if I let off the gas, the converter would stay locked sometimes all the way down to 32 mph.
Now, it locks and unlocks closer to 40 mph.
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
