wHAT DO YOU GUYS THINK OF THIS WHEEL?
Hey just wanted to get some opinion on these wheels and i have questions about the rear fitment for all you 20'' owners out there. I think the rear tire should be a 275 correct? or 285? I think these would look good on my IP and i want to pull the trigger.
Front Wheels (2)
Brand: DRIFZ
Style: VENOM
Finish: GUN METAL
Front Tires (2)
Brand: TOYO
Style: PROXES 4
Size: 245 35 20
Rear Wheels (2)
Brand: DRIFZ
Style: VENOM
Finish: GUN METAL
Rear Tires (2)
Brand: TOYO
Style: PROXES 4
Size: 295 30 20
Front Wheels (2)
Brand: DRIFZ
Style: VENOM
Finish: GUN METAL
Front Tires (2)
Brand: TOYO
Style: PROXES 4
Size: 245 35 20
Rear Wheels (2)
Brand: DRIFZ
Style: VENOM
Finish: GUN METAL
Rear Tires (2)
Brand: TOYO
Style: PROXES 4
Size: 295 30 20
I would go with a mid to high +30's offset for the front and a low to mid +40 offset on the rear with a 10" rim. You might want to drop the car an inch
(Eibach's, H&R's) to make the wheels tuck and look right on the car. A 275 on a 10" rim is about perfect, a 285 will give you some sidewall bulge and might cause a rub under hard cornering. 245 on the front is a perfect flush fit.
i think the fronts could use lower offsets, like low 30's or mid to high 20's... because of the width difference... because the G isn't really staggered to begin with
look at the picture thread, someone put on some mid 20 offsets up front, i think it'll look better with lower offsets up front for your set up... just my opinion...
Honestly? I hate multi-bolt pattern wheels. And anything named DRIFZ probably isn't that high of quality.
Save up for some wheels that will do your nice ride justice. These won't do it.
I like them...especially for a very inexpensive wheel. What is the rear lip on them?
That's not the gunmetal finish though, is it? That looks more satin...not enough gray or not dark enough for gunmetal I don't think?
that depends... he said he's going to lower it, so i think it'll be fine...
offsets will depend alot on the drop of the car and camber...
of course, looks are all subjective... one may think it's flush, another think it sticks out, and others think it's not out enough...
