Uploading files to Flash Card
Old Oct 30, 2007 | 07:45 PM
ErinB510's Avatar
Hi-
I apologize if this had been covered, but I did a search and read a ton of posts and didn't find what I was looking for.
What is the correct method for uploading and sorting music onto the Flash Card? I see that there are folder and sub-folders, but I don't really understand that. At the moment when I play my flash card in the G35 it's sorted by album and there is no association to the artist whatsoever.
I'd love for it to sort by artist. A folder for each artist and then all the songs of that artist would be ideal. Also can you play all songs on the CF card on shuffle?
Any help is much appreciated!
Thanks!
Old Oct 31, 2007 | 12:25 PM
msobetzko's Avatar
When playing from a flash card the sorting is haphazard. First off, there is no recongnition of file tags from the MP3 files. Nor is it alphabetical. My best understanding of the sorting is that it is sorted in the order the files and folders were placed onto the flashcard. That is to say, it uses the timestamp of the files and folders as they are written to the card (my observation). Windows is sometimes odd about the order it writes files when you drag and drop them (sometimes the last file in the selection is the first to be written). So it does take some planning if you care about the appearance on the chip.
I create folders on my hard drive named by artist and then create the files inside those folders. There after I drag each FOLDER one by one to the chip (single folders not selections). When dragging folders the files inside are written in the sort order that you had in windows.
Old Nov 1, 2007 | 09:26 PM
alekinci's Avatar
^ exactly
first to be placed on the CF is the first to be played by the car.
just grad and drop the songs onto the CF from the PC
Old Nov 1, 2007 | 11:33 PM
Gorn's Avatar
Utility
And this handy little utility will reorder the files on your compactflash card so that they are in alphabetic order in the G35: http://www.anerty.net/software/file/DriveSort.php
Old Nov 5, 2007 | 07:47 PM
mwells's Avatar
Hey Gorn,
Thanks for the link to sort my compact flash music alphabetically. I opened up the program and don't see how once I sort alpha how I save the order to my cf card. Am I not seeing the obvious with the program?
Any help would be appreciated.
Cheers,
Mike
G35 Torontoman
Old Nov 5, 2007 | 08:08 PM
mwells's Avatar
I figured it out. Easy peasy. I just save and quit the program and everything sorts itself out practically on my cf card.
cheers,
M
Thebaws11
Jul 2, 2021 11:36 AM
