Wiper Blades
Old Mar 3, 2008 | 01:04 AM
  #61
rsx004's Avatar
Originally Posted by Jason@Riverside
Guess they got them... mine are still on back order... weird...
Ill see if I can figure out how to take them apart next week...
Just picked up some replacement inserts myself - ever have any luck in determining how to properly replace them?
Old Mar 4, 2008 | 11:03 AM
  #62
spta97's Avatar
For those of you who have not tried the PIAA Super Silicon blades I would give them a shot. I was orginally turned off by the price (about $40 for the pair) but they last twice as long as all the other blades I have used.
My wife was crying the other day for a pair after her 6 month old G started smearing so I am off to order a set.
I run them on my Armada and turned my sister and my buddy onto them as well.
For the money, I have not found a better blade. When you install them make sure you follow the instructions which call for a through cleaning of the windshield, wipe down with the included alcohol/silicone wipes, dry for 10 minutes, wipe clean, then run the blades DRY for 5 minutes.
That last step I forgot when I first installed them and it makes all the difference in the world. The blades transfer a layer of silicone to the windsheild and help repel the rain so the wipers do not have to work as hard and give a silent, squeegee clean wipe every time
It is recommended to run them dry every once and a while to make sure you have a good layer of silicone transferred which is nice because I used to be aprehensive to use wipers to get rid of a mist for fear of damage.
Old Mar 15, 2008 | 10:12 AM
  #63
almatti's Avatar
Here's an old trick about rubber wiper blades: Clean them occassionally with a clean paper towel and DeNatured Alcohol. It removes the remanant dirty worn rubber. If the wiper are truly worn or damaged by the environmental chemicals _ Acid Rain, etc, - then they need to be replaced. i replace mine about once a year, depending on the how much they are used in 10-12K..
Old Aug 7, 2009 | 10:26 AM
  #64
cavv123's Avatar
Can some one explain how replace the blades with new wiper refills. I'm having a hard tie doing it. My OEM blade assembly is cover by a rubber sleeve. I'm not sure if that is the same with all 07 G35X's but it is very hard to get to remove the old refill and install the new one. Any idea guys.
Thanks,
Old Aug 7, 2009 | 12:27 PM
  #65
CalsonicVQ's Avatar
A pair of needle-nose pliers will do the trick.
Old Aug 7, 2009 | 08:33 PM
  #66
cavv123's Avatar
That is exactly was I was using but those damn things don't want to come out. Any tips?
Old Sep 5, 2009 | 09:49 PM
  #67
baileyt35's Avatar
Where can i get the BOSCH Icon replacement blades? I need some refills, my dealer is asking for $90 that is insane!
Old Sep 7, 2009 | 06:05 AM
  #68
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by Joaquin03
Bosch Icon ftw....
Amen!!
Old Sep 10, 2009 | 11:05 AM
  #69
sanwar2's Avatar
I just got mine replaced through the dealer and its like i think anywhere between 20-30 dollars for both of them. (I THINK)
Old Sep 10, 2009 | 01:25 PM
  #70
Iamtodd's Avatar
Just replaced mine yesterday. Had a coupon from Merchants tires for BOGO free I got the rain x latitude, paid $20 which isn't bad, Can't really say how they work because i just got 'em yesterday but i read some reviews and they looks to be ok.
Old Oct 24, 2011 | 06:21 PM
  #71
celwin's Avatar
The oem blade inserts for 07+ g34 is definately not 28895-CB08C and 28895-JK61A mentioned earler. i bought these exact part numbers and the are not the oem ones on my 07 g35. no where as thick
Old Oct 26, 2011 | 08:32 PM
  #72
Feeelax's Avatar
Lol you're 2 years late but in with the save.
So did you manage to find the right oem part?
I've yet to replaced these since I bought the car. who knows when these wipers were installed. I should get them replaced.
Marlin84
Apr 1, 2020 12:52 PM
zoop425
Mar 29, 2016 05:51 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
mcneil_g35
Aug 5, 2015 12:03 PM
