Cruise Control + Rain rant
Old Nov 12, 2007 | 11:59 AM
fecurtis's Avatar
Last night I was driving back from a friend's house and it was raining outside, nothing serious or anything. It was late, I was tired, and I like using cruise control when I'm tired, especially since it'll slow down for me if someone is in front of me. Awesome feature when I just don't feel like doing anything.
Well I try to set the speed and I realized nothing happened. At first I got pissed because I thought my CC was shot, but I tried using it this morning on the way to work and it worked just fine so I figured that the CC will not work if its raining outside. Bummer.
Old Nov 12, 2007 | 12:25 PM
TaBzRx's Avatar
hmm I highly doubt that. I'll give it a try tonight considering it's been raining almost every night here in Jersey.
Old Nov 12, 2007 | 12:29 PM
Yv12345vY's Avatar
I saw something related in a previous post about CC shutting off in heavy rain. Try searching for it.
Old Nov 12, 2007 | 12:41 PM
ChemGuy's Avatar
ICC can't see through heavy rain. It's just one of those times you can't use it (like driving into the early morning/late evening sun). If you want to use CC during conditions that blind the ICC system, just hold the CC button for a few seconds when you turn it on. This turns on plain old dumb CC which doesn't use the sensor. Just don't forget which mode you are in and run into something!
Old Nov 12, 2007 | 02:07 PM
Lemodular's Avatar
Be careful, one should not use any cruise control in poor condition. You can hydroplane or skid on ice easily.
Old Nov 12, 2007 | 02:11 PM
kvangil's Avatar
+1. I love CC when cruising on the highway, but would never use it in heavy rain, snow, fog, or traffic....
Old Nov 12, 2007 | 02:22 PM
dopey's Avatar
Whoa?!? That works? I was wondering how to get around the driving west into setting sun problem with ICC. I'll have to try this.
Old Nov 12, 2007 | 04:34 PM
fecurtis's Avatar
Absolutely, but this wasn't in a downpour or anything. Just plain old rain. I could stand in it without an umbrella and be fine. I'd never think to use CC if it were truly poor conditions.
As for disabling the ICC, I never knew you could do that. I'll keep that in mind in the future.
Old Nov 12, 2007 | 04:44 PM
treacherous's Avatar
20 Year Member
G35x
FYI: ICC will work with interval wipers turned on.
Old Nov 13, 2007 | 08:00 AM
pedropedro's Avatar
I had a very similar issue. I turned on the cc in the rain, started off working fine. Slowed down to pay a toll and went to resume, nada. Tried to reset, nada. Went straight to the dealer (it was nearby) and was informed of the "too much water on the sensor" rap. Frustrated with spending 40,000 and not having a cc that will work when I want it to. Now I read that it will revert to the "laymans" cc if one holds the button down for a bit, and I am satisfied. I am a safe driver and respect weather and road conditions, I feel I should have the option of when and how I use my cc.
Old Nov 13, 2007 | 02:49 PM
jaspergtr's Avatar
is this feature described in the manual? i'm looking to get a qx for my wife, and i can't the intelligent cruise control. how long is a few seconds?
Old Nov 13, 2007 | 02:53 PM
jaspergtr's Avatar
nevermind, my wife just spoke with the dealer, 3 seconds. now is this everytime you set it? or is it done just once when activated the first time?
Old Nov 13, 2007 | 03:21 PM
ugaexploder's Avatar
it's not a good idea to use CC in the rain. my brother used it in his z06 on I-85N and he spun out of control during a turn. the turn was on a slight incline and CC usually gives it gas to keep at the same rate of speed and when you have 400 ft-lbs of torque it's not a pretty sight in the rain. even w/o 400 ft-lbs it's still easy to lose control of your car when it's RWD and raining.
Old Nov 13, 2007 | 03:51 PM
ChemGuy's Avatar
It's when you turn it on.
Old Nov 13, 2007 | 04:20 PM
fecurtis's Avatar
Tried it today, worked fine.
Everyone here was right, to summarize:
If you have ICC and wish to use it while raining be aware:
-ICC will not work if you have the windshield wipers on
-ICC WILL work if you have the wipers set to interval
-If your windshield wipers are on the "Low" or "High" setting, you'll have to disable the ICC in order to use your CC, just hold down the On/Off CC button for a couple of seconds and you'll notice its on on your driver's info center.
It was raining this morning (minor pour) and tried using it using those methods above. Worked just fine.
