Dumb Question
Old Nov 25, 2007 | 04:27 AM
knightrider's Avatar
Dumb Question
I currently have an 03 G-coupe with 20 inch wheels on it, I am shopping for an 07/08 g sedan sport. Will the wheels from my coupe fit the new g sedan? You may need more info about my wheels, if so please post. THANKS!!!
Old Nov 25, 2007 | 12:31 PM
AlterZgo's Avatar
It really depends on width and offset. If you are running rims w/ the same width and offset as your stock coupe rims, then they will fit on an 07/08 G sedan with no problems.
If you are running wider than stock, but conservatively sized widths and offsets for a G35 coupe, you may be able to fit them on your sedan, but you may need to run narrower tires to stretch them so that they tuck under the fenders.
If you are running aggressive coupe offsets, they will for sure stick outside the wheel well on the sedan.
Old Nov 26, 2007 | 12:30 AM
Jason@Riverside's Avatar
most G35 Coupe wheel fitments will not fit the sedan, unless your current Coupe wheels are tucked under the fenders they wont work...
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
