Omfg Can Someone Please Tell Me Why This Yellow Light Is On?
Old Dec 5, 2007 | 10:46 PM
kvangil's Avatar
Most gas stations have air stations with built-in gauges now. Might try one of those... I normally keep it between 28-32 psi...
Old Dec 5, 2007 | 11:20 PM
DRIP's Avatar
Even on my Titan there is not a noticeable difference by sight when the sensor trips. Now is the perfect time to learn how to fill your tires to the correct pressure.
Old Dec 5, 2007 | 11:50 PM
calibur45's Avatar
i had that low tire pressure light 2 weeks ago also..
i brought it to the dealer.. all the tires had good pressure
they had to reset it for me
Old Dec 6, 2007 | 10:18 AM
audiophool's Avatar
Originally Posted by TIRE_SMOKE96
The max air pressure is labeled on the sidewall of your tire. I keep mine at 40 psi. You can get a tire pressure guage from Pepboys or your local parts store and they can show you how to use it too. Hope that helps.
Don't use the max pressure from the tire sidewall, use the pressure listed in the handbook or on the door pillar label.
Old Dec 6, 2007 | 10:33 AM
BrianV's Avatar
It's also worth noting that it may take a few minutes after you put air in the tires before the sensor turns off (and you need to drive for those few minutes at speeds higher than 25 MPH).
Just check the pressure in all four with a $0.99 Pepboys pressure guage (everyone should have one in their car). Inflate your tires to 32-34 PSI if the tires are cold (not driven on) or 30 PSI if they're warm.
Old Dec 6, 2007 | 10:34 AM
BrianV's Avatar
Also,
That particular icon/light is the industry standard light for low air pressure. It's not Infiniti specific, it's used on cars of all makes and models.
Old Dec 6, 2007 | 11:09 AM
kvangil's Avatar
+10000000..... 40psi is way too high.....
Old Dec 6, 2007 | 11:13 AM
Calpolytlo's Avatar
not trying to flame you, and maybe I'm wrong, but
32-34psi if cold, okay i can agree with that
but if the tires are warm, the pressure in the tires should then be higher not lower, if you're inflating to 30psi while warm, once they cool, they should be
a lower PSI under 30
or i could be wrong
another wierd thing, I bought a temp gauge, and while it gives proper readings on the rear tires, it always reads lower on the front tires, very strange to me, I have compared with gas station guages and what not any ideas?
Old Dec 6, 2007 | 11:58 AM
BrianV's Avatar
or i could be wrong
You're absolutely right, I'm retarded this morning. I should've said, 32-24 cold, 36-38 warm.
Old Dec 6, 2007 | 12:28 PM
NewGuyG35's Avatar
Just checked the tires. One of the rear tires is at 24 psi(in the cold, just woke up). I guess I have to get it up to 33.
Old Dec 6, 2007 | 12:44 PM
blindS!de's Avatar
Mine was lit up about a week ago.. filled up all 4 tires @34psi but light was still on so i did my spare too and light went off.. so don't forget to check your spare as well.
Old Dec 6, 2007 | 12:48 PM
Hikos_G's Avatar
Originally Posted by NewGuyG35
I noticed it when I jumped in my car. I have no idea what it means. The yellow light with the explanation point.
Old Dec 6, 2007 | 01:28 PM
Sieveboy's Avatar
this can't be for real
Old Dec 6, 2007 | 01:46 PM
BrianV's Avatar
The spare has a sensor too?
Old Dec 6, 2007 | 02:05 PM
  #30
blindS!de's Avatar
When i filled up the spare it only has the non tps valve stem but i'm assuming that there is also some kind of sensor for the spare tires.. unless i just soo got used to my 4runner having tps on my spare tire as well that i'm thinking there is a sensor for the spare... someone correct me if i'm wrong
