Omfg Can Someone Please Tell Me Why This Yellow Light Is On?
Old Dec 6, 2007 | 02:08 PM
  #31
06g35meister's Avatar
how does infiniti expect us to see "low tire pressure" in that, i had to go to the manual, i was like WTF???
that does not look like a low tire...
Old Dec 6, 2007 | 02:14 PM
  #32
godmans's Avatar
Originally Posted by BrianV
You're absolutely right, I'm retarded this morning. I should've said, 32-24 cold, 36-38 warm.
Thanks for the correction Kre62, please ignore what I have said
Old Dec 6, 2007 | 02:16 PM
  #33
kvangil's Avatar
Like someone else on here said...it's not infiniti--it's the standard symbol for low tire pressure on all cars....
Old Dec 6, 2007 | 02:28 PM
  #34
kre62's Avatar
Originally Posted by godmans
No offense, I am not sure if you know what you are talking about... I think you meant 32-34 WARM, 36-38 COLD
This is because 36-38 warm >> 36-38 cold ; 36-38 warm (depending on how warm) can easily be over 40 cold
You got this backwards. As air is heated it expands. So 35 warm would be like 31-33 cold. As air cools it contracts. Thats why in the winter cars preform a little better, cause the air is more dense. More air=more fuel=more POWAHH.
Old Dec 6, 2007 | 02:31 PM
  #35
Coach's Avatar
Originally Posted by blindS!de
When i filled up the spare it only has the non tps valve stem but i'm assuming that there is also some kind of sensor for the spare tires.. unless i just soo got used to my 4runner having tps on my spare tire as well that i'm thinking there is a sensor for the spare... someone correct me if i'm wrong
Full size spares (eg. 17" sedan) have sensors, donut spares don't.
Old Dec 7, 2007 | 02:10 PM
  #36
csdstudio's Avatar
What's going to happen when the next warning light comes on? "OMFG WHAT IS THIS ****!!!!"
Sorry, couldn't resist.
Old Dec 16, 2007 | 12:41 PM
  #37
NewGuyG35's Avatar
So it's been a little over a week, and I just got the light. The same tire needs air again. Is it possible it might have a nail or something stuck to the tire?
Old Dec 16, 2007 | 12:57 PM
  #38
Coach's Avatar
Yes. Of all the ways for a tire to lose air, that's the most likely.
Old Dec 16, 2007 | 01:05 PM
  #39
ernie18's Avatar
why didnt you look in your owners manual?
Old Dec 16, 2007 | 01:13 PM
  #40
Coach's Avatar
This forum has convinced me that for all the cars Infiniti has sold, they only produced about 6 owners manuals. I'm just happy I'm one of the lucky few to not only get one, but actually locate it within the car.
Old Dec 16, 2007 | 01:33 PM
  #41
ernie18's Avatar
hey i got one too thats how i knew what this yellow light is
i wonder who got the other 4?
Old Dec 16, 2007 | 01:39 PM
  #42
Christian's Avatar
My TPMS warning indicator was on for a few days last week due to the cold weather, unfortunately I couldn't find anywhere with a air compressor strong enough to increase the pressure from about 29psi back to 33psi in the weather either. It warmed back up to about 2C yesterday and the TPMS warning is gone.
Old Dec 16, 2007 | 03:08 PM
  #43
kevink's Avatar
Originally Posted by TIRE_SMOKE96
The max air pressure is labeled on the sidewall of your tire. I keep mine at 40 psi. You can get a tire pressure guage from Pepboys or your local parts store and they can show you how to use it too. Hope that helps.
Go by the pressure listed on your door. The value on the sidewall is the maximum, NOT the recommended. Once the tires heat up, the pressure goes up, so if you filled it to the maximum when cold, it would go over once in use.
The only caveats I have found is that many tire pressure gauges appear to be garbage. I have had 2 in my posession that read 5lbs different. Also, those built into pumps are even worse.
The other one is if you have changed your wheels or tires to non standard sizes. At that point, you have to do more research to find the correct pressure. Still keep it below the tire's maximum, but the wheel may have a maximum pressure too.
Old Dec 16, 2007 | 03:09 PM
  #44
kevink's Avatar
Originally Posted by kvangil
Most gas stations have air stations with built-in gauges now. Might try one of those... I normally keep it between 28-32 psi...
Those are generally very inaccurate. Maybe the specific one you use isn't...
Old Dec 16, 2007 | 03:28 PM
  #45
JOKER's Avatar
CLUB MODERATOR
it does not mean that it's low
it means that it needs your attention.
Usually cuz it's low
