Omfg Can Someone Please Tell Me Why This Yellow Light Is On?
Dec 5, 2007 | 09:16 PM
I noticed it when I jumped in my car. I have no idea what it means. The yellow light with the explanation point.
Reply 0
Dec 5, 2007 | 09:17 PM
we call that "Flower pot" LIGHT
That means that your tire pressure is low.
Check it.
Reply 0
Dec 5, 2007 | 09:18 PM
It means your tire pressure is low. Mine went on a few weeks ago and I had some tires that needed air.
Reply 0
It indicates a low tire pressure in one of the tires or a bad tire pressure sensor.
Reply 0
Dec 5, 2007 | 09:37 PM
Too bad it doesn't tell me which tire needs air. Maybe I have a nail in there. ****!
Reply 0
Dec 5, 2007 | 09:39 PM
lol just try to inflate all 4 of your wheels to the stock pressure it should go away..
Reply 0
Dec 5, 2007 | 09:41 PM
Jesus, does no one read the manual anymore?
Reply 0
Dec 5, 2007 | 09:44 PM
I only look at the pictures. And to be honest, I don't even know how to add air to a tire. I mean, I know how, but don't know how much.
Reply 0
Dec 5, 2007 | 09:49 PM
Quote: I only look at the pictures. And to be honest, I don't even know how to add air to a tire. I mean, I know how, but don't know how much.
Like someone else said "Read your manual", it will tell you what it should be, it is also on a sticker on your door post.
Reply 0
Dec 5, 2007 | 09:51 PM
no flaming ok?
The max air pressure is labeled on the sidewall of your tire. I keep mine at 40 psi. You can get a tire pressure guage from Pepboys or your local parts store and they can show you how to use it too. Hope that helps.
Reply 0
Dec 5, 2007 | 10:07 PM
If you really don't know much about it. Here is some helpful info:Click here for How to Put air in your Tires
Reply 0
Dec 5, 2007 | 10:08 PM
i am gonna flame.. or bitch i cant help it.. if u do not know how to fill tires you better have a butler or...else not own a car.
Reply 0
Dec 5, 2007 | 10:10 PM
I think it's malfunctioning. I checked the tires and they all look fine. The book says it only turns on when you exceed 16 mph. It was turned on when I was on idle.
Reply 0
Wow.
Reply 0
Dec 5, 2007 | 10:17 PM
Quote: I think it's malfunctioning. I checked the tires and they all look fine. The book says it only turns on when you exceed 16 mph. It was turned on when I was on idle.
What pressure were they, you need a pressure gauge to check if they are low. I believe the sensor will go if the tire is 4 lbs or more low.
Reply 0
