Wheel Hop...
Old Jan 23, 2008 | 01:09 PM
Jason@Riverside's Avatar
Originally Posted by Klubbheads
wow, first time seeing the differential giving up on our cars. U must have really experimented.
oh I have seen a few of them come in like this...
That was on my 350z..
now that I think of it, ive only really seen 350z's like that, havent seen a G come in here yet with the rear end out like that...
Old Jan 23, 2008 | 04:27 PM
NeverStock's Avatar
Thanks for the help guys! I'll work on throttle control some more, gonna try Bridgestone's RE01-R's pretty soon too I'll let you know how/if it changes. Don't think I'll go with a 4 - 6K launch while 'feathering' the clutch, I'd like to keep from replacing the clutch every year...
In response to an earlier reply concerning whether or not wheel hop occurs with VDC on - my experience is that only until the ECU senses the slippage then it backs off the throttle for you, wayyyy too much IMO, completely defeating the quick launch you were trying to attain.
Old Aug 3, 2008 | 05:50 AM
jabrother's Avatar
I'm a little confused. How do you spin the tires w/o hop? I've tried dumping the clutch at different revs and always get severe hop. If you slip the clutch at a 5k, you are going to cause damage to the clutch, right? In other words, how do you do a burnout in these cars? I have an 07 coupe 6 mt with bolt on mods.
Thanks,
James
Old Nov 5, 2008 | 09:01 AM
snowcrossmxz's Avatar
u have to get teh tire rpm up
if u spin the tires a little bit the tire will grab, stress the suspension which will compress, then the tire will break loose and the suspension will spring back, then the tire will grab again and it will happen again.
by getting the wheel rpm up the tire won't grab, it will spin.
pop ur clutch and hammer it, to the floor, and red line the bitch, ull get ur non hopping wheel spin.
if it starts to hop, stop and try again, u have to spin up the tires quick. if its already hopping and u hammer it more, it will hop more.
Old Nov 5, 2008 | 08:31 PM
earth0's Avatar
wow
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
