Mods
Old Feb 26, 2008 | 10:51 PM
dofu's Avatar
20 Year Member
Suspension done right - Struts, springs, and camber/toe kits, and alignment. IMO, a nice drop will make your car look nicer than nice wheels alone ever can.
Old Feb 26, 2008 | 10:58 PM
hullio's Avatar
First of all, will any of these mods (intake, pop charger, springs) affect warranty? I'm pretty sure lowering your car affects the suspension warranty correct?
Old Feb 27, 2008 | 09:34 AM
IvoryPearl07G's Avatar
lowering springs- ~$300
fujita intakes- ~$300
save remaining $300 for rims.
its the direction i took and worked greatly for me!
Old Feb 27, 2008 | 03:49 PM
ugaexploder's Avatar
save your cheddar on them hoes
Old Apr 15, 2008 | 02:12 AM
hans127's Avatar
I say this
M45 Sport Rims or any other Rims
Old Apr 15, 2008 | 08:32 AM
m1a2c2kali's Avatar
eff the hoes......its all about the ride
Old Apr 15, 2008 | 08:45 AM
chilibowl's Avatar
Do not buy intakes, they actually lose power.
You cant get an exhaust because a brand new one is above your budget
If you lower your car with just springs, you will begin to eat through front tires.
Honestly, what id suggest, is you save your dough and grab yourself a set of G37 19's. They bolt right up and look very classy yet sporty. They will also fill in the wheel well a bit more which allows you to wait a little till you drop your car, the right way.
OR, you could buy a used FI exhaust for under 900 and have about a bill n change left.
Old Apr 15, 2008 | 09:00 AM
Beebo's Avatar
^+1
btw pop charger is an intake system for the G.... its still in the works i believe
Old Apr 15, 2008 | 12:59 PM
hullio's Avatar
You literally read my mind. I looked into intakes and exhausts and read that it's mainly a sound upgrade. I think the car sounds good enough, don't want to waste a lot of $$$ to make it sound just a little better. I'm in the search for G37 or M45 rims. I'm pm'ing people on this forum who are currently selling them. Hopefully I can find a good deal.
Old Apr 15, 2008 | 02:31 PM
chilibowl's Avatar
Exhausts actually produce worthwhile gains, and the more aggresive note is an added feature. Intakes on the other hand, do not.
Old Apr 15, 2008 | 04:06 PM
brownfv's Avatar
Springs + Nismo Lip!
Old Apr 15, 2008 | 07:55 PM
silverG2007's Avatar
I'm a peformance guy.
DO NOT buy an intake or exhaust (unless you really really like the sound for some reason). You won't gain much power if any. If you want a louder exhaust, do a muffler swap (much cheaper and it'll sound the same).
Do the image mods.
Old Apr 15, 2008 | 07:58 PM
chilibowl's Avatar
Do the image mods.
Old Apr 15, 2008 | 08:35 PM
Armanius Maximu's Avatar
Is it worth (cosmetic wise) the $$ to change the springs to get a drop, if I don't currently have enough $$ to buy new wheels, so I will be using the stock 18" wheels in the G35S?
And if yes, any recommendations out there for inexpensive springs? Thanks!
Old Apr 15, 2008 | 09:02 PM
  #30
SDGenius's Avatar
get lowering springs, save the rest for mods after more research. DON'T buy the Fujita... no heat shields = hot air intake FTL
