Drifting in G35 with AT?
Old Apr 26, 2008 | 09:01 PM
SDGeneralCounsel's Avatar
Originally Posted by Ionic
I've tried it in manual mode and it's quite difficult because of the open rear dif.
Exactly. You can push it in manual mode, but you can't really sustain the drift. I thought the 5AT came with the same rear end as the 6mt before I got the G35. You can however do a custom LSD job and bump up the power and you should be fine.
There is a BMI video (I think on the new RX-8 DVD) of one of the first turbo charged Z33's in japan which was a 5AT and Tsuchia was drifting it pretty easily.
There is also a pretty famous guy in japan that drifts a turbo altessa (IS300 in the states) on the touge.
Old Apr 26, 2008 | 09:04 PM
chinabean's Avatar
^ i want to see this video lol
Old Apr 26, 2008 | 09:05 PM
G35Now!'s Avatar
Moderation-free
Originally Posted by Lawy'dU
Exactly. You can push it in manual mode, but you can't really sustain the drift. I thought the 5AT came with the same rear end as the 6mt before I got the G35. .
The Sport models come with VLSD, whether AT or 6MT. To me the difference is that with the 6MT you can really break the rear wheels lose by dropping the clutch on a downshift, whereas with the AT it's a smoother transition so it's harder to break loose. Not impossible, of course
Old Apr 27, 2008 | 02:49 AM
Wei's Avatar
Wei
anyone make a clutch/mechanical diff for the new G yet?
wonder if the 350z interchangeable...
Old Apr 27, 2008 | 03:04 AM
not for the 5AT that I know of. I've heard you can use the LSD from the 6MT lsd's but it takes a little custom work.
The title of the video is Best Motoring International "rotory reborn". They show the turbo Z right before the tuned Z battle.
Old Apr 27, 2008 | 03:07 AM
you mean clutch kick. It's definitely more difficult to drift a AT car. But seriously, the guys on Top Gear drift every car they drive and many are automatics...
To really get the G or the Z sideways, mt or at, you need more power. The G and Z are far too heavy.
Old Apr 27, 2008 | 09:08 AM
kmuniz78's Avatar
It's not drifting, but if I can make my car do this: https://g35driver.com/forums/media-share-v36-sedan/213489-my-day-funtion-tuned-va-ngc.html, then drifting shouldn't be an issue! Click on the photobucket link in this thread to see what I'm talking about.
Old Apr 27, 2008 | 10:19 AM
r0csfinest's Avatar
Originally Posted by kmuniz78
It's not drifting, but if I can make my car do this: https://g35driver.com/forums/showthread.php?t=213489, then drifting shouldn't be an issue! Click on the photobucket link in this thread to see what I'm talking about.
how did you do that? any techniques?
Old Apr 27, 2008 | 11:03 AM
kmuniz78's Avatar
Quite simple:
1) Roll windows up (cuts down on smoke in the cabin);
2) Put the car in DS Mode (preffered method is to use paddle shifters)
3) Roll (1st gear - 5-10mph) into a CLOSED area (saftey of course);
4) Turn the wheel slightly to whichever side you plan on whipping the tail end too;
5) Toggle between 1st and 2nd (if need be) - Pump (yes I said pump) the gas peddle as car turns and remains in a spot for a 1 -2 sec.; get's car moving again . . .
6) Oh, put on your favorite music!
Old Apr 28, 2008 | 01:14 AM
Wei's Avatar
Wei
so the 6mt is physically different? i would think the diff internal and case should be the same...
Old Apr 28, 2008 | 01:53 AM
just the gas pedal doood. It's a simple doughnut, not even close to drifting. Plus it looked like the pavement was wet too.
Old Apr 28, 2008 | 01:54 AM
negative. It apparently is a little different. Even the final drives on the AT pumpkin are different from the ones that come with the 6MT
Old Apr 28, 2008 | 02:10 AM
g35dawson's Avatar
From everything I've read and heard, Quaife makes a drop in LSD for the cars that came w/o it from the factory, and it's supposedly the best on the market. If you want to change out the one from a Z or one of the Sport G's you have to have some kind of axle stub thats different from the non-VLSD to the VLSD model. Quaife's is supposed to be the ****e though
Old Apr 28, 2008 | 02:17 AM
r0csfinest's Avatar
i only asked cause videos of people doin doughnuts are so popular thinking maybe there was something more to it lol
Old Apr 28, 2008 | 03:44 PM
  #30
kmuniz78's Avatar
It did rain. However, makes no difference in the G!
