View Poll Results: VQ35HR Oil Consumption Poll
No noticeable consumption between oil changes
114
83.21%
Up to 1/4 quart consumption
2.92%
Up to 1/2 quart consumption
4.38%
Up to 3/4 quart consumption
1.46%
Up to 1 quart consumption
4.38%
More than 1 quart consumption
3.65%
Yikes! My engine seized or started knocking from low oil
0%
Voters: 137. You may not vote on this poll
Old Jun 8, 2009 | 02:46 PM
  #31
Cabad85's Avatar
Mobil 1 5w-30 dino oil at 3000miles, then Mobil 1 0W-40 since 6000miles and now doing 5000mile intervals. No noticeable consumption, currently at around 22000 miles.
Old Jun 8, 2009 | 07:26 PM
  #32
johnnyzee's Avatar
havent noticed any drop in oil levels
Old Jul 9, 2009 | 09:30 PM
  #33
mifesto's Avatar
i purchased my 07 g35x in May of 09. noticed oil was already at max wasnt brown at all so i knew the dealer changed it and didnt put alot of mileage on it. bought at 42k miles, now at almost 44k, oil is alil browner but no significant oil burning
Old Jan 18, 2011 | 01:35 AM
  #34
a17z's Avatar
I'm noticing around 3/4 quart of consumption. About 3,500 miles since the last oil change (5W-30 full synthetic). I have a 08 6MT with ~50k miles.
Old Jan 18, 2011 | 07:39 AM
  #35
soundmike's Avatar
^ double-check that the oil pan nut is tight. Happened to me once, i failed to torque it down to spec and it *very* slowly leaked. Only noticed it when i was under the car one day and saw a little black pool on the plastic underbody shield.
Old Jan 24, 2011 | 04:30 PM
  #36
InfinitJazz's Avatar
74,000 miles on my V36 with no oil consumption. Oil changes are done with synthetic every 6-7k miles.
Old Jan 25, 2011 | 10:38 AM
  #37
_RR_'s Avatar
No oil consumption here. Every 3k miles with mobil 1 5w30
Old Sep 23, 2013 | 04:07 PM
  #38
vqsmile's Avatar
I'm at 77K, average about 8K between (synthetic) oil changes since new, but I've never had to add between changes. It's usually down a bit on the stick, but not like it's even worth bothering with topping off between changes.
Old Sep 23, 2013 | 05:42 PM
  #39
stockae92's Avatar
Just over 60k miles, usually around 3750 miles oil change at dealer, no noticeable oil consumption regardless of driving style.
Old Sep 23, 2013 | 05:51 PM
  #40
con's Avatar
con
Added a quart a couple of weeks ago. Used a Jug of Mobile 1 EP 5w30 and the EP filter ~5500 miles ago. Nothing dramatic it was just towards the lower line in the morning when I checked. I don't know if it was at the top of the line when the oil was changed using 5 quarts or 1 jug.
Old Sep 23, 2013 | 08:12 PM
  #41
blnewt's Avatar
Our 07 (now owned by a friend) has 95kmiles w/ no measurable oil consumption, regular 5-30 dino oil 3,500 mile OCI.
Our 09 w/ 50k miles using 5-20 Pennzoil Platinum w/ no measurable oil consumption, 6k OCI and great UOAs. I also use M45/56 oil filters for all my oil changes, filter's about a third larger than our puny G oil filters and my UOAs have been better since going to those filters (Bosch Premium BTW).
Old Oct 19, 2013 | 04:55 PM
  #42
fuster's Avatar
original owner of a 2006 G-35 6SP sedan. Amsoil, changes every 4-7,000 miles, oil samples lab tested each change (all have come back normal, no contaminants, normal oil component levels and viscosity index and oil ready for continued use). Typically have to add 2.5-3 qts between changes.
Their replacement engines have the identical manufacturing defect.
Old Oct 19, 2013 | 07:38 PM
  #43
Blue Dream's Avatar
I drove ttrank's car solo
You do realize this is a thread for the HR motors right?^^
Old Oct 20, 2013 | 05:35 PM
  #44
t04ptgt's Avatar
08 g35x. zero oil consumption between 5k changes on Mobil 5w30. 101k miles and counting. very impressed with this motor.
Posted from G35driver.com App for Android
Old Oct 20, 2013 | 05:42 PM
  #45
Lartytiejdke3's Avatar
Originally Posted by t04ptgt
08 g35x. zero oil consumption between 5k changes on Mobil 5w30. 101k miles and counting. very impressed with this motor. Posted from G35driver.com App for Android
Good to hear!
