Anyone else have trouble pumping gas?
Old Mar 18, 2008 | 05:28 PM
MrJohnTan's Avatar
Originally Posted by max2k1
How do you manage to run the car on empty ??
please tell me -- I could save a whole lot on gas bills
j/k
haha funny...
Old Mar 18, 2008 | 05:33 PM
PR G35S's Avatar
I have problems pumping Gas every time I see the price on the pumps
William
Old Mar 19, 2008 | 08:10 AM
airhoppz's Avatar
Originally Posted by WUKILLABEEZ
That has happened to me also but in my case it definitely isn't due to a malfunction of the car. Around here some of the gas stations put a limit on the amount of gas you can get, usually $50s worth. After I've pumped $50s worth of gas the pump cuts off and you can't get anymore. I think you can probably get around that though by starting a new transaction with a different credit/debit card.
That sounds like something I'd file a lawsuit over.
Old Mar 19, 2008 | 08:38 AM
Kuneff's Avatar
I have been told it is a valve inside the fuel tank that causes that. I am about to change mine and see if that fixes it.
Old Mar 19, 2008 | 12:38 PM
WUKILLABEEZ's Avatar
Why would you file a lawsuit over something like that? Any business or company reserves the right to limit the quantity of goods you can purchase from them. No different from electronic stores limiting people to only purchasing one Nintendo Wii, etc...
Many service stations here limit your gas purchase to $50 and it has never bothered me.
Old Mar 19, 2008 | 01:30 PM
thanmad's Avatar
Ya, i don't know that you can pull off a lawsuit for it, but i agree it is quite annoying. I came from a Jeep Grand Cherokee with a 23gal tank and can easily dropped over $80 into that thing in one filling.
I just laugh at the "you ran it on empty for too long", where in the manual do they say you should keep the tank over 1/2 way filled? If a fuel pump is having trouble getting gas all the way up from teh bottom of the tank, perhaps you designed the car with the wrong fuel pump
Old Mar 20, 2008 | 08:46 PM
bfspider's Avatar
I get this at some stations. Sometimes I have to slide the rubber guard on the pump back to get the pump to put gas in the car.
I just try to avoid the troubled ones. I think that the pump is over pressurized and the sensor in the pump keeps kicking off when you're pumping gas.
Annoying!
Old Mar 20, 2008 | 09:52 PM
306HP's Avatar
This happened to me at a BP gas station, it never happens on the no name brand stations though
306HP's Avatar
Old Mar 21, 2008 | 12:33 PM
G35DekThai's Avatar
Yes, I do.
Everytime I pumped the gas, I looked at 3.55/gallon ( I live in Houston, TX.) and it makes me bleeds inside...
Old Mar 22, 2008 | 06:08 PM
CoppellStereo's Avatar
as i said before, mine cuts off randomly to, and someone said to turn the handle to the side, and pump. i tried this, and doesn't work all the time, but then i pulled out the pump a few inches, then turned the handle to the left, and i was able to put 8 more gallons in this way, i was just afraid to pump it all the way up since it probably wouldn't shut off until it was overflowing
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
dseet
Oct 11, 2015 12:40 AM
Hogbone
Sep 28, 2015 06:44 PM
