Slight Steering shimmy???
Our 2008 G35 Journey Model with the Sport 18" rims on it has only 2,200 miles on the odometer. The car went in for service due to me feeling a slight shimmy or vibration around 75 Mph. This shimmy is no where to the point that its bad bad but you can feel sometype of shimmy. The dealership drove the car and balanced the wheels and everything checked out OK, No Bent rims, all tires balanced perfect.
My question to everyone is does this seem normal cause these new Infiniti's are setup to drive more like a BMW type of car with more steering feel?
Does anyone else have the same experience?
I had the same problem with my new G35S, after few attempts to balance the tires,It was determined that the front tires have a flat spot from sitting on the lot for 3 months. The dealer replaced the front tires - no more vibrations.
As for BMW steering feel, my E36 M3 was much better than the G35 but newer BMW's lost their tread-mark steering feel and the difference between 335i and G35S is a matter of preference.
I took my new 2008 G35s back the very next day due to a shake or shinny at freeway speeds. Found that both front tires had lost a balance weight (or some other lame excuse). They rebalanced them and the care was PERFECT.
Unfortunately, a common issue that lots of drivers just can't seem to identify. Go with a rebalance first before pulling the car apart.
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
