07 G35 Sedan's Navi Screen
Old May 17, 2008 | 12:15 PM
lbyyz's Avatar
The navi screen on my 07 G35x does not get to its fully brightness on startup, it usually takes a couple of minutes before it does. In other words, it's noticealy dimmer than it should be when the car is first started, especially in the morning. Is that normal at all? or should i get it checked out by the dealer?? anyone else experiencing the same thing???
Old May 17, 2008 | 12:27 PM
mIKE's Avatar
It is the same as any LCD screen; the cathode takes a few to get up to full brightness.
Old May 17, 2008 | 04:12 PM
lbyyz's Avatar
Thank you for your reply.
But doesn't LCD use liquid crystal technology as opposed to CRT(cathod ray tube)?
Old May 17, 2008 | 04:36 PM
jl114's Avatar
Probably referring to the backlights of the LCD - which can be LED or cold cathode fluorescent bulbs.
Old May 17, 2008 | 09:16 PM
07 G35S 6MT TEC's Avatar
Never noticed any lower brightness on my LCD at startup so you may want to have it checked by the dealer.
Old May 17, 2008 | 09:18 PM
glocker99's Avatar
When your headlights are on, the nav display and purple circle aroudn the odometer is not very bright. When your lights are off, the nav and purple circle are much brighter.
Old May 17, 2008 | 09:22 PM
G35Now!'s Avatar
Moderation-free
True, although I think it depends on how you have them set? You can set for full brightness at night, don't know why you would tho.
Old May 18, 2008 | 08:36 AM
lbyyz's Avatar
Once again, thanks for all the replies.
Unfortunately it still behaves the same way when headlights are off. Think I will get it checked out during next my next service anyways!
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
tiguy99
Jul 26, 2015 01:39 PM
laksjd84
Jul 24, 2015 05:12 PM
