Inaccurate fuel system readings??
Old May 19, 2008 | 01:04 PM
g35_6gear's Avatar
I am curious if anyone has had this issue. My car was always fairly accurate when it came to fuel range and the computer. Lately my car goes down to around a 5-10 mile range on the computer and I fill it up. The car will only take about 15 gallons of fuel when the capacity is around 18 gallons.My range is shorter than it used to be bu my MPG is the same. It's like the tank is holding the extra fuel on one side of the tank and not ransfering over to the passenger side pick up anymore. It used to be an issue with the older 350Z's and G's that had their fuel pumps modified for turbo kits. I am wondering if there is an issue with the stock system in the 07's now with the siphon system that transfers fuel from the drivers side of the tank over the floor hump the passenger side fuel sensor/pump assembly.
Old May 19, 2008 | 01:40 PM
fecurtis's Avatar
Probably not, most cars will tell you that you need to fill up before you need to.
Old May 19, 2008 | 02:08 PM
RCK's Avatar
RCK
Fuel tank also hosts a gauge that measures some aspect of the engine system. I forget what it is at the moment. Regardless, that gauge needs about 3 gallons in the tank to operate, hence the gas indicator is about three gallons short of the actual capacity. The actual fuel capacity is 20 gallons, but apparently the gauge can be damaged if the fuel in the tank goes below the 3 gallon reserve.
CalsonicVQ's Avatar
Fyi, the low fuel indicator will light up when there is 3.125 gallons left in the tank. For me that's approx 65 more miles until I'm completely empty. That's how I calculate my DTE.
Old Jun 10, 2008 | 06:25 PM
bettersnr's Avatar
'08 G35 w/ only 16 Gallon indicated capacity
This is an interesting and a very precise number. May I ask where it comes from?
Infiniti consumer affairs has no information re this issue and my area dealerships have no idea how much the car should "take" from "empty".
My '08 G35 Journey shuts off the fueling nozzle after only 16.0 Gal. with fuel gage on 'E' mark and the range no longer calculating DTE (shows hyphens). So 20-16 => 4 Gallons left.
Sure, I've never had a vehicle take the tank capacity when "empty" but this is a bit much. How much do you '08 owners manage to put in and what are the gages reading before you do?
Dealer says to bring it in, but how will they test it I wonder...
Thanks!
Old Jun 11, 2008 | 09:38 AM
LiquidGx's Avatar
With ****** as my miles to empty, I can get 17.8 gallons in my 08.
Old Jun 11, 2008 | 10:07 AM
UltimateGee27's Avatar
no your wrong..... its 3.125735263
Old Jun 11, 2008 | 11:46 AM
carz's Avatar
or could it be 3.14 Pi
Old Jun 11, 2008 | 03:07 PM
rpm&my_G35's Avatar
3.141592653589793238462643383279502884197169399375 10582097494459230781640628620899862803482534211706 79821480865132823066470938446095505822317253594081 28481117450284102701938521105559644622948954930381 96442881097566593344612847564823378678316527120190 91456485669234603486104543266482133936072602491412 73724587006606315588174881520920962829254091715364 36789259036001133053054882046652138414695194151160 9...
Go Ahead...Check It. lol
Old Jun 11, 2008 | 04:38 PM
ugaexploder's Avatar
i never noticed this, i always fill up when i have a few gallons left
Old Jun 11, 2008 | 04:39 PM
CalsonicVQ's Avatar
Thanks!
I came across the number in either the user's manual or the factory service manual. The number was stated as 3-1/8 gals (I converted to decimal to get 3.125). One time, the DTE had lighted up and I drove 40-50mi more before I filled it up (I wasn't try to test my DTE calculation; I just had no time to make a trip to the gas station!). I filled 19.x gals. My calculation seems to work pretty well for my car.
Old Jun 12, 2008 | 10:46 AM
mpgxsvcd's Avatar
Wink
Now that is cutting it close!
Old Jun 14, 2008 | 02:31 AM
bettersnr's Avatar
So here's what I've found out.
CalsonicVQ: Thanks. I found that statement of 3-1/8 gallons left when low fuel warning light comes on in the MWI service manual section, pg7.
I also found that fuel level is ~5-1/4 Gal less than full when fuel gage needle indicates ~3/4 of the major tick spacing below the F. i.e. the needle is just above the major tick indicating ~ 3/4 full. My gage's needle is at top left of the F when tank is as full as I can get it. Also that tank's capacity is 20-1/8 U.S. gallons.
Which gets us to the problem of getting it full.
After lots of searching and reading (that I should have done prior to my first post) I discovered that past G35 models had plenty of problems being fueled to full capacity.
While the service manager at my dealership assures me the '08 (maybe '07) are all new, my experience and that of others indicates Infiniti still has some work to do. At least, in educating it's customers about this issue. He also confirmed the split gas tank and that there is a pump to shuttle fuel to the other side, but that's a hard thing to do. Chronically running at very low fuel levels may damage the fuel pump as it is cooled by the fuel.
Basically it appears that fast pumping rates, to get people through gas stations quickly these days, doesn't give the fuel emission/recovery system time to vent. The result is the nozzle gets shut off. I found even after an hour of sitting, I couldn't add fuel to a non full tank. FWIW, I noticed that there's no hiss when opening the fuel cap like my prior cars of other makes had.
However, If I pump slowly (not the nozzle's maximum rate) AND I don't fully insert the nozzle, I can fully fill the tank. Meaning I can put in what it seems it should be taking based on gage indications and the reference values I mentioned above. Also when full now, the fuel gage needle is at the upper left of the F.
So, pump slowly, back out the nozzle and try lifting the nozzle handle and you may also be able to fully fuel your ride and get predictable results.
While I finally found an Infiniti service guy who was responsive and helpful about this, the conversations with others were a waste of time and disappointing.
Given the history of the G35 with regard to this issue, I don't think that's acceptable.
Thanks for the help (postings of PI and such excluded) and reading all this .
Old Jun 15, 2008 | 05:51 PM
MiniRX7's Avatar
That was very useful informatino.
I found out that i could sometimes not fill the car all the way up to full (even the gauge doesnt go past FULL). and this makes sense!!
What a silly design!
Old May 9, 2011 | 10:38 PM
hrp783's Avatar
had this problem today, I was filling up and i could only fill up 3/4 full... sometimes after i push it a little while i can only fill up 16 gal. thats when completely full..
I never thought about it damaging the pump by going almost bone dry...
thanks guys.
Jusseth
Sep 13, 2020 12:25 PM
miata007
Aug 17, 2015 04:36 PM
lemmy999
Jul 25, 2015 12:13 PM
