So the little weights on the rims fell off
Old Jun 5, 2008 | 09:17 PM
Pdubz's Avatar
^^ if you dont know what i mean.. i guess its the balancers on the rims.. they look like a row of square weights...
this morning before school i went outside to wait for my friend to pick me up.. i look on the ground and see the strip of weights.. i said to myself i hope those aren't mine.. so i walk to my car and check the rims... looks like they are mine.. wtf... how does this just fall off...
would this significantly effect my driving??
is this covered under warranty?
Old Jun 5, 2008 | 09:25 PM
mIKE's Avatar
you need to have your wheels re-balanced.
You're going to have a bumpier ride; the worse the balance, the worse the ride.
Also, your tires can wear strangely too
Old Jun 5, 2008 | 09:31 PM
Pdubz's Avatar
its weird how it just fell off like that. im about to super glue it back on
Old Jun 5, 2008 | 09:33 PM
dopey's Avatar
unless you know exactly where they came from, do not put them back on. And do NOT super glue them. When you get new tires they'll likely need to rebalance and they may need to put the weights in different places.
take the car in to a tire shop (or the dealer) and get them to rebalance them for you. This is likely not going to be covered under warranty, but it's not really that expensive, a good tire place will do a single tire for around 20 bucks.
Old Jun 5, 2008 | 09:35 PM
Pdubz's Avatar
im jk about the super glue
Old Jun 5, 2008 | 09:58 PM
Deezflip's Avatar
If you can find that exact spot where it fell off from, you can buy some 3m molding tape(its gray tape with red plastic backing, the same tape used for those splashguards) and stick back on.
It's usually the cleanest part or the part where the some of the tape is still stuck on is usually the sign that if where it originally fell from.
...oh and make sure to clean the back side of weights and the area of the wheels with alcohol so it sticks nicely.
Old Jun 6, 2008 | 09:30 AM
fecurtis's Avatar
It doesn't cost much to rebalance tires. Enjoy the lovely ride quality in the meantime.
Old Jun 6, 2008 | 09:40 AM
mbritt80's Avatar
everytime I go in for a rotate and balance they keep trying to get away with putting the weights on the outside fo the wheel. thats when I put some powder on it and smack them b*tches
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
