Coolant Bypass?
Old Aug 9, 2008 | 02:32 PM
KulG35's Avatar
Question Coolant Bypass?
http://www.infinitihelp.com/diy/gsed...ss_install.htm
Why would you NOT have coolant running? Has anyone done this, what is it supposed to do?
Old Aug 9, 2008 | 03:13 PM
EWG35's Avatar
that's for <2006 sedans not 2007 +
Old Aug 9, 2008 | 03:21 PM
jsmonet's Avatar
if you live somewhere the temp never gets below 50-ish (so cal for the most part) then you don't need the coolant running through the TB to keep the butterfly from freezing in place
Old Aug 9, 2008 | 03:23 PM
KulG35's Avatar
Ahh, so it's to keep from freezing...thank you!!!
Old Aug 9, 2008 | 07:59 PM
Joe_Camel's Avatar
No, just the opposite. The bypass is to prevent warming up the throttle body. This is good in climates where it doesn't freeze, not a good idea if you live up north.
Old Aug 10, 2008 | 12:49 AM
KulG35's Avatar
What is the benefit, I like in Orange County... the video was for a 03-06 G, would the 07 G35 benefit from it? Again what does this give, performance gains for ?
Old Aug 10, 2008 | 01:04 PM
Naveed2126's Avatar
Those things can mess up idling too. Did it on a car last summer and the b*tch was idling at 1500-2k rpms until I reversed the bypass...
Old Aug 10, 2008 | 01:18 PM
SDGenius's Avatar
huh... then why does it tell you to never close it at temps below 55*F???
Old Aug 11, 2008 | 04:30 AM
jsmonet's Avatar
how would running 190f-ish fluid through the t/b prevent the t/b from warming up?
Old Aug 11, 2008 | 09:47 AM
IvoryPearl07G's Avatar
did this on my setnra specv for some added cooling(along with a thermal gasket and CAI)
It seemed to help keep the intake air charge/manifold/runners cool.
but i did go through 3 Throttle bodies(TPS went out on them.)
Old Aug 11, 2008 | 12:15 PM
LiquidGx's Avatar
Waste of time unless you are trying to improved .001 in teh 1/4 mile.
06g35
Feb 14, 2022 05:59 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Usman Ali
Sep 22, 2015 06:59 AM
