Didn't know the tire pressure was suppose to be in the low 40's
Old Dec 10, 2008 | 01:35 PM
NewGuyG35's Avatar
Well according to the tire person. I could have sworn I saw in the manual that it has to be in the mid 30s, which is where I had it, but lately I was getting the flat tire light. I took it to the tire guy to check them out and he said I need them to be no more than 44. Your thoughts.
Old Dec 10, 2008 | 01:52 PM
kool_yaar's Avatar
NO way. FOR STOCK: in winters you should have it higher to avoid the light.
Summer: ~33
Winter: ~36
Old Dec 10, 2008 | 02:02 PM
GEE35FX's Avatar
44 I really hope you are joking. That is way too high. I run 34 psi all around and sometimes bump it up to 35 psi max.
Old Dec 10, 2008 | 02:03 PM
ShanesG's Avatar
I run 32 year round!
Old Dec 10, 2008 | 02:08 PM
sredish's Avatar
I run mine a tad higher due to the softer sidewalls on these Kumhos, I tend to run 38 front / 36 rear.
Old Dec 10, 2008 | 02:10 PM
NewGuyG35's Avatar
Well I refilled the tires to 40-42.
I previously had them at 30, which is what might have caused the flat tire light to go off.
Old Dec 10, 2008 | 02:41 PM
hobbs's Avatar
I think the guy was probably talking about the maximum pressure for the tires which is different from what infiniti would recommend.
Old Dec 10, 2008 | 02:44 PM
nghiars's Avatar
as you drive the tire heats up and tire pressure increses... i would have it at 38 max in the winter, preferrably 36-37 psi front and 35-36 rear for winter, 34-35 front and 33-34 rear for summer
Texasscout's Avatar
Thirty is too low. Your gauge is maybe +/- 1 to 2 psi and that COULD put you in the 28-29 area which DOES set off the TPM.
Old Dec 10, 2008 | 02:45 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
you said no more... not no less. He was simply stating the maximum pressure that the tire is rated for. industry standard is 32-35psi cold.
-GP-
Old Dec 10, 2008 | 02:54 PM
NewGuyG35's Avatar
How can I remove some air from the tires? Can't I just use that stick thingy to measure the pressure to remove air?
Old Dec 10, 2008 | 02:56 PM
GEE35FX's Avatar
Just depress the center pin in the valve stem.
Old Dec 10, 2008 | 02:59 PM
Yv12345vY's Avatar
Check the sticker on the inside of the driver door. My 06 says 33psi all around.
Old Dec 10, 2008 | 03:27 PM
terrycs's Avatar
I've always wondered about the sticker. Doesn't it only apply to people with stock tires? What is the recommendation for folks with 19s and 20s? I would think the pressure has got to be higher than the manufacturer recommendations. Comments?
Old Dec 10, 2008 | 03:29 PM
Yv12345vY's Avatar
I think it'd only apply to stock size tires on stock wheels.
