clear projector lenses
Old Dec 16, 2008 | 01:26 AM
narek330's Avatar
http://store.theretrofitsource.com/p...b4fbbcbf43c1f0
Has anyone tried changing the lenses on their ride with these lenses?
Old Dec 16, 2008 | 02:07 AM
SxExCx's Avatar
yes, and Matt at The Retrofit Source is a really cool guy.
If you swap the lenses, you need to mod the cutoff to take full advantage of its use. Read the DIY
Old Dec 16, 2008 | 04:10 AM
Csquared's Avatar
Where is the DIY?! Is it worth it? So would we get the really cool bluish tint if we did this?
Old Dec 16, 2008 | 11:38 AM
E-Ticket Ride's Avatar
The purpose of the lens swap is to get a sharper cut off line. If you drive up to a wall, you'll see that the cut off line is rather soft and fuzzy in appearance. It will not change the color of the tint (only a bulb will do that).
Old Dec 16, 2008 | 12:34 PM
SxExCx's Avatar
^you are wrong, adjusting the cutoff will change the color of the beam
Old Dec 16, 2008 | 12:37 PM
SxExCx's Avatar
this picture is of a clear lense with the cutoff mod and stock bulbs
Old Dec 16, 2008 | 12:57 PM
IrockAG35's Avatar
Ohio G Club moderator
whats the point?...why spend the money on new lenses just for a sharper cut off line..
Old Dec 16, 2008 | 12:58 PM
Csquared's Avatar
yeah I want to know the point and also how hard is it to change the lens?
Old Dec 16, 2008 | 01:05 PM
SxExCx's Avatar
It just a mod to look better than stock. The process is pretty involved and requires precision work.
Old Dec 16, 2008 | 01:07 PM
Csquared's Avatar
hmm that sucks looks like i'm not going to be doing it hahaha. Where is the DIY again?
Old Dec 16, 2008 | 02:04 PM
redlude97's Avatar
The point is to get color at the cutoff so when people view your lights they are purple/blue/white, without using aftermarket high kelvin bulbs which sacrifice significant amounts of output. This is what you see coming at you
Old Dec 16, 2008 | 02:07 PM
redlude97's Avatar
BTW, those lenses are for the 06+ g35 projectors, not for the 07+ sedan projectors which IIRC use a 3" lense. I haven't seen a DIY for those yet. Talk to IvoryGT about getting your 07+ headlights modded if you are truely interested.
Old Dec 16, 2008 | 04:29 PM
Exactly. That pic shows a modded cutoff shield. If you don't mod the shield and only do a lens swap, you only get a sharper cutoff. You do get some color above the cutoff line, but the actual temperature of the light produced doesn't change.
Modding the shield involves bending the shield either away from or toward the bulb. Changing that distance produces the color above the cutoff line, but again, the basic color of the beam itself doesn't change (which is what I was trying to relay to the other poster).
Old Dec 16, 2008 | 05:01 PM
Csquared's Avatar
right i kinda get it, but still doesn't work on our cars right and it's like a major mod, which i do not want to do myself.
Old Dec 16, 2008 | 05:07 PM
It's not "major," but it does involve opening up the light and disassembling the projector. More than anything, it's time consuming.
IIRC, the STi lenses work, as do the replica ones that are 3". If you go to hidplanet.com and ask around or check the classifieds, I'm sure you can find a set for $100.00 or less. I don't know if it's a "drop in" type of install, meaning you can just swap the lenses and go. You may need to experiment and adjust the shield distance (like I was saying the the previous post) to obtain a sharp cutoff line or to get rid of a double cutoff line, so it may not be something you'd want to do just to get the blue flicker and sharp cutoff.
You can always ask IvoryGT in the marketplace to see if he's done it before. I'm sure he has, and he could tell you if shield spacing is necessary or not. If it's not, and you're comfortable opening up your headlights, then I'd say it could be worth the effort. If you have to fugg with the shield, or worse yet, make custom shields, I say **** it personally and it's not worth it. I tried making custom shields for my old lights, and you have to be PERFECT or every little abnormality is easily seen.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
