Urgent Tire Help!
Old Dec 18, 2008 | 06:05 PM
g35sedan5at's Avatar
Urgent Tire Help!
hey guys, i need responses asap as i need these tires before i leave on jan.2 and will be ordering them from tirerack, but they will be a christmas gift.
i have an 08 sport so my OEM tire sizes are as follows:
Front- 225/50/18 sidewall- 4.4 inches
Rear- 245/45/18 sidewall- 4.3 inches
As we all know, oem tires arent really that great and are super expensive. i had dunlop sport maxx's on my old g and i loved them. im looking at these sizes
Front- 235/40/18 sidewall- 3.7 inches
Rear- 255/35/18 sidewall- 3.5 inches
i knwo its smaller than stock, will this be fine????? please, any advice is appriciated, and if you guys have any other tires to suggest for the sport wheels im all ears.
THANKS!
Old Dec 18, 2008 | 06:21 PM
JOKER's Avatar
CLUB MODERATOR
you rear needs to be taller then front.
So get a bigger sidewall for the rear.
235/255 is a good width, you don't wanna go too much over 255 for the rear
you can also do 245 on the front if you want.
Old Dec 18, 2008 | 08:09 PM
GEE35FX's Avatar
Wow you are way off on your sizes.
Just the rear tire going from 245/45/18 to 255/35/18 your speedo will be off 6.2% . The new size is 1.7" smaller diameter. Thats too much. It is best to stay within 2% or better.
255/45/18 for the back would put you much closer to stock diameter
245/45/18 or 235/45/18 would be good for the front
Old Dec 18, 2008 | 08:49 PM
G35Now!'s Avatar
Moderation-free
Quite a few of us are running 235/50/18 front, and 255/45/18 rear. That really expands your tire choices; pics are available in the Tech forum (where this thread is moving )
Old Dec 18, 2008 | 09:43 PM
thanks, i guess my hope of the dunlop sport maxx is over. o well. ill see what i can find in the sizes you posted G35NOW!
Old Dec 18, 2008 | 11:34 PM
blnewt's Avatar
Here's a thread that may be of interest, the pics of my current tires are on page two, I've got about 6k miles since I posted those pics and am very happy w/ the tires and performance thus far.
https://g35driver.com/forums/tech-07...corners-2.html
Old Dec 20, 2008 | 12:10 PM
how about 225/40 Front and 255/40 Rear. its about .3 inch total lost in diameter from the stock sizes but these two are nearly identical with both having 4.0inch sidewalls.
Old Dec 20, 2008 | 12:22 PM
GEE35FX's Avatar
I ran 255/40/18 and the diameter was too small, and I didn't like the error in my speedo so I got rid of them. Going smaller diameter like that also gives you more tire gap. But if that is what you want go for it.
Old Dec 20, 2008 | 12:27 PM
GEE35FX's Avatar
Your calculations are out comparing 245/45/18 with 255/40/18. It is not .3" total lost in diameter it is more than double that , it is .7" difference in diameter.
Old Dec 20, 2008 | 12:31 PM
you are correct my friend, i failed to remember its .3 added to the circumference so its like .3 on top and .3 on bottom.
Old Dec 20, 2008 | 12:45 PM
GEE35FX's Avatar
LOL, I had to double check it myself
Here: http://www.canadiandriver.com/tools/tirecalc/tirecalc.htm This is one of my favourite tire calculators for comparing tire sizes
Old Dec 20, 2008 | 03:06 PM
alright, i think ive decided on 235/50 and 255/45. anyone know if i order from tirerack that ill be able to install them before jan.2???
Old Dec 21, 2008 | 01:57 AM
ez-g's Avatar
THANKS!
I run 245/45/18s on my front rims and 255/45/18s in back. Actually a better fit than stock if you go by the design rim width on tirerack. Will never go back to the stock tire sizes, these sizes are ideal.
Old Dec 21, 2008 | 09:01 PM
neal.a.nelson's Avatar
It's more important what you buy than where you buy
In fact, I disagree with your premise: OEM tires aren't all that great and are super expensive. #1. Our OE tires are pretty great. #2 Cheap tires will ruin what is now a great car. You've got 18 inch wheels, so expect to pay $800+. It comes with the territory. Do your research on Tire Rack, etc., then buy locally. This is the biggest decision you've got as an owner, and there is no upside to rushing it. FWIW, I chose Sumitomo HTRZ IIIs and I believe they are just as good, will wear a little longer, and they are a little cheaper. That's about the best you can hope for.
It sounds like you've accepted that you can't go wild on changes to size, I would say its the same for treadwear rating - don't go from 140 to 500+. Good luck, and let us know how it works out.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
