Headlights for 07 Sedan
Old Feb 3, 2009 | 06:46 PM
duslep's Avatar
Hey all, I am new to the G35 world and i rebuild cars. Anyways bought a wrecked sedan and am having a heck of a time finding headlights for a reasonable price. Does anyone know where i can get stock or aftermarket ones for cheap? Also would these fit or no? http://www.migicute.com/03ig354db.html I appreciate all the help i can get. Dustin
Old Feb 3, 2009 | 07:06 PM
narek330's Avatar
those defintely wouldnt fit there not the correct lights unlless u have a coupe 07. and the cheapest ull be able to find the headlights for ours would be on ebay unless u want to wait around at a junkyard for years until u find a set. also if u can find a body shop that has a membership with a dealership which i did before you can get the light at a wholesale price
Old Feb 3, 2009 | 07:39 PM
terrycs's Avatar
Search the wrecking yards ... they are out there.
Old Feb 3, 2009 | 08:24 PM
kool_yaar's Avatar
^+1 else expect to spend at least 6-8$ for used off ebay
Old Feb 3, 2009 | 09:49 PM
g35_6gear's Avatar
You can find them on Ebay for a couple hundred bucks. That's where I got mine from.
Old Feb 4, 2009 | 08:55 AM
snowcrossmxz's Avatar
does ur car have the adaptive head lights or regular ones. that will make a big difference in price as well
Old Feb 4, 2009 | 10:59 AM
duslep's Avatar
I'm not sure if there adaptive or not? How would I tell? its just a regular RWD Sedan, as far as i Know.
Old Feb 4, 2009 | 11:16 AM
you know where the VDC button is to shut off VDC?
(its above the driver left knee)
next to that switch will be another switch labeled AFS (i think its afs)
its not like the push button VDC switch, its a rocker switch with an on and off position.
that switch turns on the headlight system.
though i suppose even if you car has it. you could still get the regular lights and use them just fine. you just won't have that feature.
my 07 has it and its kinda cool. the lights bend around a curve at night.
if you do find both versions of the head lights, let us all know the price difference between the two
hope that helps
Old Feb 4, 2009 | 11:26 AM
on second thought.
if you car has the adaptive head lights, then it should also have the smart cruse control. where it will pace the car in front of you and keep you a set distance from it. (which is GREAT in traffic on the highway)
to check for this, u can ether check to see if you have the ICC sensor on ur front bumper, which is a black flat piece of plastic located in the mesh of the front bumper. its a little off center on the drivers side and is about the size of a pack of cigs from the side.
also look on the right side of the steering wheel, you will see a second button below the cruse control button, the second button looks like it has a ladder on it. thats how you set the distance to the car in front of you.
Old Feb 5, 2009 | 01:54 AM
titan13qb's Avatar
you know they dont fit when the site spells infiniti wrong...
Old Feb 5, 2009 | 08:37 AM
docaam's Avatar
those do fit old Sedan but not the new one...you havent mentioned yet which G you have?
Old Feb 5, 2009 | 08:47 AM
the post is called Headlights for 07 Sedan
Old Feb 5, 2009 | 09:05 AM
docaam's Avatar
thats what i was thinking the picture in Dustin's link shows for lights for 06 sedan
Old Feb 5, 2009 | 09:10 AM
mm good point, OP chime in and let us know. -06 or 07+
all my talking about the adaptive headlights was for the 07+ only
Old Feb 5, 2009 | 04:26 PM
Grav's Avatar
Try these guys...they are a national clearinghouse of used parts:
http://car-part.com/
They have several listed now.
