no traction with 20's
Old Feb 25, 2009 | 08:10 PM
kool_yaar's Avatar
i think youre talking about the VSLD viscous slip limited differential, yes it dies help but not sure if its worth the money as i havent driven the journey...
Old Feb 25, 2009 | 08:15 PM
J2S2M's Avatar
I have driven both the Journey and the Sports. I honestly don't think the limited slip differentials make a noticeable difference.
Y not look into aftermarket suspension upgrades such as coilovers, sway bars, strut bars, or better tires??
Old Feb 25, 2009 | 08:37 PM
rocco spinelli's Avatar
Well i've got the car lowered and have sway bars what 20 inch tires would you recommend, what do you think of 19x10 275/40 rear. Would it rub?
Old Feb 25, 2009 | 08:39 PM
G35Robby's Avatar
This is really weird because my car came with VLSD but i have a journey.
It even says it on the package deal I received from my broker.
Old Feb 25, 2009 | 08:52 PM
E-Ticket Ride's Avatar
It shouldn't.
Does the VLSD light illuminate on the dash when you break traction?
Old Feb 25, 2009 | 08:55 PM
G35Robby's Avatar
when i turn off vcd and burn out it doesnt.
Old Feb 25, 2009 | 09:13 PM
J2S2M's Avatar
Robby, I am almost positive you do not have VLSD if you have a Journey. Because as far as I know, only the Sports model come with limited slip differentials.
Old Feb 25, 2009 | 09:21 PM
rustyeleio's Avatar
Maybe people are confusing the VDC with LSD (VLSD)? VDC is standard on all G35 but the LSD comes with the sport package, G35S.
VDC is the electronic stability and traction system that selectively cuts power and/or applies brakes to keep the tires from spinning out of control or the car from going sideways. This is very much a safety oriented option.
The LSD/VLSD is more of a "mechanical" device in the rear differential that doesn't allow the left wheel from spinning anfd the right wheel doing nothing. It is a perfomance option rather than a safety option and helps on hard acceleration or aggressive turns.
Not 100% scientific explanation but I think it should be reasonable.
Old Feb 25, 2009 | 09:24 PM
G35Robby's Avatar
I know thats why I'm saying its weird because it says I have it on the sheet the broker had given to me. He even said it himself. I know this comes with the S models but could this be an option i guess
Old Feb 25, 2009 | 09:36 PM
same olg's Avatar
Just thinkin can the op have an alignment issue, to much negative camber maybe
Old Feb 25, 2009 | 09:54 PM
Polo08816's Avatar
Originally Posted by rocco spinelli
I was thinking smaller wheel bigger tire more flex to the road
I was thinking....the larger the wheel, the heavier it is and the more gangster you look.
Trust me, when you're on a 45 profile tire or less, side wall flex isn't too much of an issue.
Old Feb 25, 2009 | 10:38 PM
stardust's Avatar
Seriously, doesnt everyone know that the 08 Journey with the SPORT package is the exact same car is the "sport"?
Which also includes the... you guessed it VLSD
Old Feb 26, 2009 | 12:07 AM
EnviedG35's Avatar
Originally Posted by stardust
Seriously, doesnt everyone know that the 08 Journey with the SPORTS package is the exact same car is the "sport"?
Yea....the sticker on mine says "2008 Infiniti G35 Journey Sport"
Old Mar 4, 2009 | 11:14 PM
G force's Avatar
Rocco, you mentioned you have the car lowered. What is the camber on your rear? Perhaps you arent getting proper contact on the middle and outside of your tires.
Picture of your car's rear might help.
Old Mar 4, 2009 | 11:21 PM
  #30
EWG35's Avatar
Sure but Robby said he has the VLSD in his Journey. It's not a Sport Journey.
So this does not apply.
On a side note I don't think you can turn of the VLSD, you can turn of the VDC. He is confused.
