bumpy ride quality with sedan?
Old Apr 9, 2009 | 12:59 PM
Coach's Avatar
Originally Posted by matador
so i checked the PSI on my tires, and they are at 37. I ll bring them down to 33 and see if it improves.
but also, i have the 18s, and i noticed both my front and rear are the same size, 245/45/18s. But according to the sticker in the car the fronts should be 225/50/18.
what kind of difference would this make if any?
They're very close to the same height, just a little wider.
The 245/45's will be about 0.2 of an inch smaller diameter than 225/50's (less than 1%), sidewall height is almost identical.
Old Apr 9, 2009 | 01:40 PM
kilrbz's Avatar
You're going to notice the imperfections in the highway more as you go faster in any car. Driving the G at around the speed limit it should be pretty smooth and quiet. Bring it up to around 80 and you might notice little bumps that you didn't notice before. This is because the suspension has less time to react to the changes in the roadway at higher speeds.
As far as the suspension being jittery, I don't really think it is. Maybe more than some sedans, but less than many. Its definitely smoother than the Mazdaspeed6 I used to drive, and also smoother than the Maxima SE I had before that.
Old Apr 10, 2009 | 05:55 PM
matador's Avatar
i notice it more when i am going around 80. i guess i ll just get used to it.
i came from a honda accord, so big change.
i'll try 225/50 like the manufacture recommended next tire change, which wont be for a while.
fun car tho =)
Old Apr 10, 2009 | 06:22 PM
kmuniz78's Avatar
Did you test drive the vehicle before you bought it? How did it feel then, compared to now?
Old Apr 10, 2009 | 06:28 PM
vps221's Avatar
Nothing is wrong with you're car. They just have really tight suspensions. So you do feel alot of road bumps and if you hit a big enough dip it will feel like you are going airborne. I should know as I was driving "sporty" on the highway and hit a few dips. Lets just say its nerve wrecking but the car never lost control.
Old Apr 10, 2009 | 07:32 PM
matador's Avatar
they dont have to be big enough dips. i do feel like im going airbone, but i never lose control.
i m just being paranoid or something. i just gotta get used to the sporty setup.
Old May 7, 2009 | 05:25 PM
smr514's Avatar
i can't complain about the ride quality on my 08 G35S... i came from 06mustang GT on 20's with bald tires.
Old May 7, 2009 | 07:42 PM
boss81's Avatar
I lowered mine and put on 19s. Let's just say I feel more of the road, but not that bad.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
smartin0924
Aug 13, 2015 07:29 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
EasySausage
Jul 14, 2015 11:17 PM
