Old Jul 10, 2009 | 10:02 AM
306HP's Avatar
Question ?
What does it mean when you get a message in the same place where you get your maintenance reminder message when a picture of a tire comes up. So when an oil can would normaly come up to remind you that you need to take it in for an oil change, I am getting the tire instead.
I initially thought its the TPMS but I am not sure about this, the wife just called to tell me so havent checked the tires yet.
Old Jul 10, 2009 | 10:59 AM
kool_yaar's Avatar
Its no big deal if its showing up on the center red lcd screen where the mileage is shown. That is just a pre-set reminder by either you or your dealer to remind you to check your tires and assure everything is fine, its not a car generated warning or anything.
Usually set by the dealer to remind you to get your tires rotated for a longer life if you have non-sports sedan, i have mine switched off from settings within the cluster keep increasing the mileage until it drops back to "-".
Hope this helps
Old Jul 10, 2009 | 11:33 AM
306HP's Avatar
Yes, thats exactly where the warning sign is, I agree with you, that should be exactly what it is. Thanks
