YIPES!!! water in the headlights...
Old Jul 20, 2009 | 01:55 AM
firozu's Avatar
theres water inside my headlights...... no visible damage on my headlights tho....
Old Jul 20, 2009 | 02:28 AM
E-Ticket Ride's Avatar
A lot of water, or water from condensation?
If your lights are modified, take it back to the dealer and have them warranty them.
Old Jul 20, 2009 | 03:06 AM
Beebo's Avatar
pics?
Old Jul 20, 2009 | 10:16 AM
AesonVirus's Avatar
I think he meant, If your lights are NOT modified, take it back to the dealer and have them warranty them.
The dealer won't help him much if the lights have been cracked open and modified.
Old Jul 20, 2009 | 11:15 AM
Yep. Typo, thanks bro
Old Jul 20, 2009 | 02:00 PM
SVLRx's Avatar
had a little in mine, a whole lot of condensation on the inside. and the light wouldn't turn on, mine were replaced under warranty.
Old Jul 21, 2009 | 11:12 PM
firozu's Avatar
ok so when i got to the dealer they were gone im guesing it was juss condensation cuz its been so hot nd humid here in fl
Old Jul 21, 2009 | 11:23 PM
IrockAG35's Avatar
Ohio G Club moderator
if your under warranty, bring it in to the dealer. if not pull HL out and bake it at 260 for about 8 mins.(no bulbs,ballast,ignitor or wire harness)..no need to open them just press them together all around the seal..chances are your sealent has a small gap...youll need to do this soon..if your ballast gets wet your HID will not work..i recently resolved this problem in an HL myself..gl
Old Jul 21, 2009 | 11:24 PM
IrockAG35's Avatar
ohh and also check your rubber seals around your top/lower caps and ballast seal
Old Jul 22, 2009 | 11:26 PM
dghboybigboy's Avatar
Buddy of mine had the same thing, defect...go to dealer and warranty it like some people said. Should replace it.
Old Jul 31, 2009 | 04:10 PM
TNC 718's Avatar
Went through that today. Every two weeks, my driver's side headlight would go out. Did this four times already. Each time, I took it to the local Infiniti dealer, and they'd replace whatever at no charge. First the bulb, then the bulb and balast, then the bulb. Today, they finally figured out that there's a crack somewhere in the headlight. I thought something was up since every time after I washed the car, the damn light would go out. Didn't see any condensation, though. They won't replace it under warranty for me, and I can't even upgrade to '06 headlights without voiding the warranty. OEMs are expensive as hell. Should I man up and get the OEMs or just go cheaper with halos or '06 projectors?
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
alessandro
Oct 8, 2015 09:29 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
