Anyone use AMSoil ATF?
Old Nov 21, 2009 | 11:31 AM
Linner's Avatar
I still have some amsoil atf from left over from my lexus and i wanted to change my atf fluid this weekend, it says that it can replace Nissan Matic D, J & K, has anyone switched over?
i ask this bc i read some threads that said smatic has replaced the jmatic so i just want to be sure
Old Nov 21, 2009 | 07:02 PM
pfarmer's Avatar
I think this may well end up as a warranty issue. It most likely is not the same as the Nissan branded fluids. Regardless if it has the same characteristics you may want to read the manual.
The following is from an 08 manual and noticed that compared to the wording of other fluids such as oil it contains a warning about your warranty. In other places it also includes the word 'required' rather than 'recommended':
'Use only Genuine NISSAN Matic J ATF. Do not
mix with other fluids.
Using automatic transmission fluid other
than Genuine NISSAN Matic J ATF will cause
deterioration in driveability and automatic
transmission durability, and may damage
the automatic transmission, which is not
covered by the INFINITI new vehicle limited
warranty.'
Note that Nissan has replaced Matic J with Matic S as a requirement but you would most likely be ok with either.
In this area I would recommend either leaving it alone (unless you have some reason to do otherwise (mileage) or change it out with the Nissan product so as to make sure you keep your warranty intact.
Old Feb 25, 2016 | 09:19 PM
abrecos's Avatar
Just check on official Amsoil website and they confirm that new Amsoil Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid can be used with Infiniti matic S fluid.Here is.
Applications
AMSOIL Signature Series Fuel-Efficient Synthetic ATF is recommended for transmissions and other applications that require any of the following specifications:
AISIN-WARNER AW-1; BMW 83 22 0 142 516, 83 22 2 152 426; CHRYSLER MOPAR® 68157995A, SP-IV; DSIH 6p805; FORD MERCON® LV, SP; GM DEXRON® VI; HONDA DW-1®; HYUNDAI/KIA SP-IV, SPH-IV, SP-IV-RR, NWS-9638, SP4-M; JASO 1A-LV; JWS 3324; MERCEDES BENZ 236.12, 236.14, 236.15, 236.41; MITSUBISHI SP-IV, ATF J3, ATF-PA; NISSAN Matic-S, Matic-W; SAAB 93 165 147; SHELL M-1375.4, M-1375.5, M-1375.6, M-L 12108; TOYOTA WS; VOLVO 31256774; VW/Audi G 055 005, G 055 162, G 060 162, G 052 540; ZF S671 090 255
Old Feb 25, 2016 | 11:02 PM
vqsmile's Avatar
Applications
Rather than just believing everything the company selling you on their "Super-Duper-GeeWizz-compatible-with-every-transmission-type-known-to-mankind" product says, I'd still want to be sure it was approved by the company that built your transmission.
.02
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
IkonG35
Aug 10, 2015 09:33 AM
newg37
Jul 26, 2015 09:32 AM
