Cargo Net - wrong one? missing d-hooks?
Old Dec 8, 2009 | 12:56 AM
chillstatus's Avatar
So I just ordered a cargo net from everythingg35.com (http://www.g35parts.com/G37-Sedan-Tr...99c1-jt000.htm). However, it's too short? The hooks that I have are on the passenger and driver sides, not against the rear trunk panel that are shown in this photo:
http://www.roadfly.com/new-cars/wp-c...-cargo-net.jpg
Did I order the wrong cargo net or am I supposed to have those hooks there? I'm so confused. Was I supposed to order this cargo net instead http://www.g35parts.com/G35-Sedan-Tr.../999cjp001.htm ?
Thanks
Old Dec 8, 2009 | 08:22 AM
gooddeal2's Avatar
I think the net looks fine but the original net has a small loop in the middle of the net, so, you can pull (make) the net bigger when you want to put things there. There're only 4 hooks, 2 on the top as your picture and 2 on the bottom.
Old Dec 8, 2009 | 08:31 AM
JOKER's Avatar
CLUB MODERATOR
The picture you posted is M's trunk and not G's
if that's the net you got it's prolly M's net and not G's.
Old Dec 8, 2009 | 10:29 AM
Pitman's Avatar
I got my Cargo Net from Circle Infiniti on eBay. Only $15 bucks shipped, fits like a glove.
Old Dec 8, 2009 | 12:06 PM
I did some searching and it looks like there's two versions of the cargo net -- a long one and a short one?
Anyway, are the hooks inside your trunk for your cargo net against the sides or are they against the back end of the trunk (facing rear)?
Old Dec 8, 2009 | 07:19 PM
JOKER's Avatar
CLUB MODERATOR
Short one is used in M models only.
Long one is for G models.
Both of the links you posted say that it's a G sedans cargo net. But they one that they sent you is for M sedan.
So tell them that they sent you the wrong one.
Also I think that G35s coupe cargo net will fit your sedan just fine. It is also longer net. So if it cost cheaper you can get that.
Check with riverside guys here on the forum. They should be able to hook you up with a good price.
Old Dec 8, 2009 | 07:50 PM
gooddeal2's Avatar
I don't think he can use the coupe net. It's way too long thus it won't be able to hold anything. The net in the coupe is not designed right, anything I put in there will be out all over the place by the time I get home.
Old Dec 8, 2009 | 07:52 PM
JOKER's Avatar
CLUB MODERATOR
could be.
I thought coupes trunk is smaller than sedans.
Old Dec 8, 2009 | 08:16 PM
gooddeal2's Avatar
Originally Posted by JOKER
could be.
The height is shorter but the length is longer. It's longer b/c Infiniti doesn't put the clips next to (or on) the back "wall". It's located about 5-6" away from the back. It's very close to the place where you see the Emergency box (look at the picture above).
Frostbite91
Aug 2, 2015 04:59 PM
pxlds
Jul 30, 2015 01:31 PM
ClwMike
Jul 23, 2015 12:55 PM
