Question on Wheel Weights
Old Feb 4, 2010 | 05:51 PM
frybecker's Avatar
I had the tires replaced on my OEM 18" sport rims last week at a local Big O Tires. When I washed the car over the weekend I noticed that the wheel weights that were nicely located on the inside center of each rim had been removed and when the new tires were balanced and installed, they replaced the factory weights with those cheesy weights that are clipped to the side of the rim. They are on the back side of rim and you would never see them w/o looking under the car, but I am curious if there was a performance beneifit in having the original factory weights in the center of the rim or if it is just for aesthetics?
This may not be a big deal but it still bugs me a little bit.
Old Feb 5, 2010 | 01:12 AM
braddahjon's Avatar
I have been workin with tires for years, to be honest all that matters is if ur steering wheel shakes over 60mph. It is a half *** way to balance but it still works. next time u can ask them to use only sticky weights.
Old Feb 5, 2010 | 03:43 PM
johnnyzee's Avatar
To balance a wheel properly, you will have two weights, front and rear of the rim.
The most accurate way to balance a wheel is to have weights on the lips of the rims. Because we have nicer alloy wheels, they stick weights on the rim behind the spokes to prevent damaging the surface on the front lip.
On the rear of the rim, weights clipped on the rear of the rim are ideal.
Basically, what they did is perfectly OK...so long as they never put the clip on ones on the front surface, rear is OK to be clipped on, and ideal.
***I used to work at a tire shop in high school.
Old Feb 5, 2010 | 04:40 PM
terrycs's Avatar
I always wondered which one stayed on the wheel better.
Old Feb 5, 2010 | 06:10 PM
nghiars's Avatar
they both stay on pretty well but Im wondering now as well.
Both have their uses but there isnt really a better/worse one.
If the wheel is off balanced towards the face of them rim, they should use the stickied weight so its closer to the face of the rim.
other way with clips.... the stickied weights just allow for more options without making your wheel look ugly as they can stick anywhere.
jsimonk
Dec 22, 2023 03:49 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
mushu
Jul 15, 2015 03:55 PM
