Back driver seat floor wet!!
Old Feb 11, 2010 | 08:23 PM
smetoye1's Avatar
Originally Posted by Brian-g35
Does this happens only when it rains? It's been raining here recently and problem just occur...
yeah, it would be after heavy rain. the water would roll down the windsheild and into the opening the installer left in the gasket on the fire wall. for some reason the rear foot well is lower than the front so the water would roll to the back seat.
i would check all the gaskets on the firewall first, then have the dealer check the sunroof drain for clogs
Old Feb 12, 2010 | 01:02 AM
Calvin's Avatar
Overglorified Altima
Originally Posted by smetoye1
i had that problem with my 07 sedan. the dummy that installed my sub removed the firewall gasket under the steering wheel and rain water leaked in and rolled to the back foot well
Can you take a picture of where this is and of what you did?
Here are the two wires coming through my firewall. The holes are not sealed (if I shine a light into the holes from the engine side, I can see the light leak through from the inside of the car). There are three holes (one is empty).
Old Feb 12, 2010 | 10:51 AM
mrclowny's Avatar
It's been raining a lot in LA lately.. So i checked my floors and lucky for me it was dry.. But then again i drive my other car when it rains and park the G in the garage..
Old Feb 12, 2010 | 12:34 PM
Mr. Samster's Avatar
i am having the same problem as smetoye1. I tried using silicone to cover up the hole but its not working so i mite ending up duck taping it... i know its ugly but not many pplz look under there anyways.
Old Feb 12, 2010 | 12:37 PM
GAU-8's Avatar
Do you all have sunroofs? If so, you might have a drain tube either clogged or coming loose allowing water to drain in somewhere. Does anyone know where the drain tubes follow through the structure?
Old Feb 12, 2010 | 12:38 PM
Calvin's Avatar
<-no sunroof here.
Old Feb 12, 2010 | 12:39 PM
mrclowny's Avatar
Shouldn't this be covered under warranty?
Old Feb 12, 2010 | 12:52 PM
well...if you have a sub installed and the installer is running the wire through that firewall rubber piece but just pulled it out instead of poking the wire through then there will be a gap where the water will leak into. Only when it rains hard then the water will get inside, but its drizzling then there wont be water in there.
Old Feb 12, 2010 | 06:27 PM
smetoye1's Avatar
it looks like someone drilled thise holes. mine already had a gasket in it and i just stuck a hole inthe gasket and put the wire through it. i gotta charge my cam but ill try to get a pic. u may wanna try silicone until you find a gasket that will fit it
Old Feb 12, 2010 | 06:38 PM
smetoye1's Avatar
im trying to post the pics not sure if its gonna work
Attached Thumbnails Back driver seat floor wet!!-dsc02512.jpg   Back driver seat floor wet!!-dsc02511.jpg
Old Feb 14, 2010 | 02:12 PM
Calvin's Avatar
^they work. thanks!
slider_ua
Jul 29, 2015 04:17 PM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
brian_z
Jul 20, 2015 01:30 AM
