Horn sound has changed?!?!?
Old Feb 21, 2010 | 06:18 AM
Defratos's Avatar
You're Despicable
Question Horn sound has changed?!?!?
Hi guys,
Ok last Thursday I drove into my cousin's driveway, and scrapped the whole bottom end pretty bad (right underneath and in between the driver and passenger seats) I basically scrapped the Y-pipes before the resonator on the Invidia.
Now I also scrapped like mad again when driving out
Anyway I looked under the car and only a bit of the Heat wrap has been torn off, nothing else seems to be damaged.
Now Friday I came to honk my horn and it sounded funny, it's not as load as before and it sounds slightly muffled. I've taken a look at the horn and all wires and everything seems to be in place. The only thing that has changed is my scrapping the car from the bottom and I can't see anything damaged.
So what could make my horn change notes like this?
Old Feb 21, 2010 | 08:37 AM
johnnyzee's Avatar
i'd say your horn is on its way out. only time a horn ever changed notes on me is after honking it ridiculously for a world cup soccer party.
Old Feb 21, 2010 | 09:05 AM
Defratos's Avatar
You're Despicable
lol "football" party you mean
Yeah well it's funny because I haven't been over using it or anything, I'm wondering if it's something to do with the battery or my Hidden number plate mechanisim
Old Feb 22, 2010 | 08:46 AM
johnnyzee's Avatar
yes you're right, football...hahaha, damn Americans!
i'd definitely look into that hidden plate mechanism of yours. I wouldn't blame the battery if your car starts and generally holds charge.
I'm not 100% here, but I'm sure the G has 2 horns which sound off simultaneously when you press the horn. One of these may have been disconnected during your plate mechanism install. My Camry has 2, not sure of the G, I assume it would as well, but one needed replacement not the other...but the tone changed which told me I had an issue.
Old Feb 22, 2010 | 08:58 AM
JOKER's Avatar
CLUB MODERATOR
just honk it few more times till it starts honking normally.
Prolly some **** stuck on the diaphragm
Old Feb 22, 2010 | 05:15 PM
codeflux's Avatar
also check the power connectors - one connector may have gone loose, and one horn could be mute.
Old Feb 23, 2010 | 03:18 AM
tg1234's Avatar
You are aging with your car. This is the first sign You are not as horny anymore. Your hornieness fades away.
Either that or the car reached its Puberty. But that would be easy to find out. Check if you find some hair around the exhaust tips and front fascia.
If these are not the right answer maybe your horn actually needs some service.
Old Feb 23, 2010 | 03:54 AM
Defratos's Avatar
You're Despicable
The G does have 2 horns, one might just not be working right. I'm pretty sure it's not down to the number plate mechansim because it only just started last Friday and I've had the mechansim on for like a month now.
I'll see if anything seems disconnected.
You know I think you might be right Joker, the sound seems to be improving everyday, I just gotta get in there and see if there is anyting stuck.
by power connector you mean the connections that actually go into the horn?
Ummm, hummm, dunno what to say to this one lol
Old Feb 23, 2010 | 11:53 AM
johnnyzee's Avatar
That explains it perfectly!
Old Feb 23, 2010 | 01:06 PM
nghiars's Avatar
I think you're just hearing things. pun intended.
Old Feb 23, 2010 | 04:22 PM
codeflux's Avatar
yes. i would check them. also, one of my horns went out once when i was driving in very heavy rain - but once it dried out, it started working again.
Old Feb 23, 2010 | 04:29 PM
miltoda's Avatar
My horn started sounding muffled right before my battery went dead. Might want to check the CCA left in your battery.
Old Feb 24, 2010 | 02:16 AM
Defratos's Avatar
You're Despicable
battery seems fine, connections seem fine, I'll have to take more time out
chinee
Jun 10, 2024 07:48 PM
underworld
Aug 6, 2015 01:36 PM
kinetek
Aug 3, 2015 04:25 PM
atk08
Jul 30, 2015 03:12 PM
Rehman2009
Jul 27, 2015 03:23 AM
