In-cabin air filter and Engine air filter
Old Mar 8, 2010 | 01:21 PM
simsimi1004's Avatar
I need to know where i can buy
in-cabin air micro-filter and
the 2x engine air filter.
I live in vancouver,bc,canada so local is cheaper for me.
anyways
For the engine air filter, i saw that there is 2 clips, so i unclipped it and try to pull it out vertically but no luck. should i pull harder or do i have to do something else? not sure, couldn't find any instructions.
anyways link to the parts would be great and something that you have used/is using would be good.
thanks.
anything else i should do at 28 000 kilometers? (17k miles)
i rotated my tires for the first time, and do oil changes at 6000-8000km intervals, (3.7k miles)
Old Mar 8, 2010 | 01:34 PM
Jeff92se's Avatar
Red Card Crew
Most any auto store will have both. The airbox has 4 clips and you have to unscrew the 10mm bolt that supports the airbox.
It's a pain to replace to I end up disconnecting the maf sensor and accordian tube and pulling the entire thing out to replace the filter. A bit more work but alot less chance at mangling your new filter trying to install it.
Old Mar 8, 2010 | 01:53 PM
TwilightSedan's Avatar
www.infinitihelp.com has a complete tutorial video on engine air filter replacement. I haen't done it yet but i'm sure it's not only two clips.
mj_39's Avatar
hey talk to Mike from ztune! they are located in burnaby. I just picked up oem air filters from them, prices are very comparable to US prices. Awesome guys!
also the oem filters pop out after you take off those 2 clips, if you need a hand im in vancouver also, just grab the parts and i can help you out
its a 5min job
Manny
Old Mar 8, 2010 | 01:59 PM
im having trouble finding the video.. so many 1st gen videos but i cant find 2nd gen.
Old Mar 8, 2010 | 02:11 PM
kool_yaar's Avatar
just unclip the 2 clips and pull up and a little towards the engine and it will pop right out, no need to take any bolts off. however the incabin filter is another story, still easy but requires patience and time. There is DIY on it.
Old Mar 9, 2010 | 02:13 PM
ultraman1017's Avatar
amazon got very good deals for both
Old Mar 9, 2010 | 05:05 PM
vs
also can any1 actually give me links to parts that they have bought and is using?
its not that im lazy but i never bought car parts online before and i have u guys approval that the filter is made for my 2008 g35x model.
Old Mar 9, 2010 | 08:02 PM
rpm&my_G35's Avatar
www.autopartsway.ca
I have used them and they are good and had my order in less than 24 hours. Shipping is free on orders > $75.
There are cheaper places.
https://g35driver.com/forums/v36-diy...crofilter.html
Old Mar 9, 2010 | 08:03 PM
Mr. TG35S's Avatar
I just replaced both cabin and engine air filters for the first time last weekend. The cabin filter is a bit of a chore but the DIY on it is very helpful.
For the engine filters, it is just the 2 clips. But, I had a problem getting them out also until I figured out that what you are lifting out is a square holder that the filters slide into from the side. When you try to take them out, sometimes the filter tilts out towards the rear of the car and hangs up on airbox. I had to stick my finger into the opening and push/tilt the filter back towards the front of the car and flush back into the holder, then the whole unit slid right out.
FYI< I used a Micron Carbon Cabin Filter and AFE Pro Dry Air Filters.
Good Luck!
Old May 8, 2010 | 02:31 AM
what do u guys think, oem is 60$ but this one is only 21$....
Amazon Amazon
do u think theres going to be a big difference in quality?
for the engine air filter im just getting oems from infiniti part usa at 15$ x 2.
Old May 11, 2010 | 03:03 PM
Glover997's Avatar
the guy is talkin about the OEM drop in filters only
Old May 11, 2010 | 03:49 PM
LightsOut's Avatar
SIETESG
http://www.amazon.com/gp/product/B00...A2OBK8JO9EJ9HZ
2 months later and you still havent purchased a filter.
wayyyy over thinking this... get the cheapest priced filters, they all do the same.
Old May 11, 2010 | 03:56 PM
gmotion04's Avatar
mine was around $16 shipped from amazon and its arm n hammer takes out nasty *** smells install was quick and painless
Old May 11, 2010 | 08:59 PM
pwebb's Avatar
ha! easiest filters to change in any car ever...
takes more time to take the new filters out of the box than actually swapping the old ones out...
